  • Online
#1394
Il est possible qu’il soit en mode de protection du firmware.
Les bugs sont souvent liés au chipset rev comme 1.x & 2.x
Je vais regarder ma carte PCI-E avec un I225-LM Rev 3.0
Last edit: 1 year 8 months ago by admin.
  • Vitaliy
  • Vitaliy's Avatar
1 year 8 months ago
#1403
How much did you pay? Link?
  • Online
#1404
  • Vitaliy
  • Vitaliy's Avatar
1 year 8 months ago
#1408
What chip used? V or LM. I read 226V has same bug as 225V :(
  • Online
1 year 8 months ago
#1411
Me they are i225-LM and yes cerla key affects the version just the Rev 3.0 is not affected a priori
