- goose280672
No it happened before that, it was working fine and then just stopped working so I was trying to fix it.
Last edit: 1 year 11 months ago by goose280672.
I think it is disabled (this will explain why the activity LEDs are off) or it is completely out of order on everything if enabling or disabling the chipset via Setup does not work
- goose280672
Yes when I enable it there is still nothing, I think it is completely dead.
- avatardiablo
1 year 10 months ago
hi
I tried to recover the backup made before the upgrade. in the NVM folder I have the files Dump.bin and dump.eep.
but when I run the command: EEUPDATEW64e.exe /nic=1 /d NVM\dump.bin I get the following error: Image size larger than flash size, aborting!
why?
thanks
why?
thanks
Try doing a UEUPDATEW64e/? to see if an other command is not needed
