- Jodragons
1 year 10 months ago
Bonjour,
j'ai mis à jour sur ma carte ASUS ROG STRIX B550-F GAMING (WI-FI) et tout c'est bien passé.
La procédure de mise à jour est très bien détaillée, en 1min c'est fait.
Vraiment merci.
Vraiment merci.
1 year 10 months agoConfiguration
- Tadeo
On ASUS STRIX Z-590A when trying to flash this firmware I'm getting this error
Aborting installation because driver already exists. Run install /y to override!
To Exit,
Check EEPROM Image information:
LAN is Non-vPro SKU
EEUPDATE v5.38.10.00
1 6 00 00 8086-15F3 Intel(R) Ethernet Controller (3) I225-V
1: Shared Flash image update FAILED! Pointers in Shadow RAM are corrupted
[uninstall.bat] Removing iQVW Driver - SUCCESS
The Computer will shut down to take effect after pressing any key, then you can press power button to turn on it, thanks!
Press any key to continue . . .
To Exit,
LAN is Non-vPro SKU
i7-11700K / ASUS Z590-A Strix/ Crucial Ballistix 64GB 3200 CL16 / XFX AMD RX 6800 16GB/ 2x SSD 970 Evo Plus 1TB and 2TB / PSU: NZXT C850 / DELL S3422DWG, Windows 11 22H2
it is possible that there is a problem with the drivers, check that you have the latest drivers, then install the drivers from the pack and relaunch to see
unless there is i225 protection in the setup
The following user(s) said Thank You: Tadeo
- Tadeo
ok, It's done. Image was written successfully. Thanks.
