Hello everyone,
Fdrsoft
  • helzayat
  • helzayat's Avatar
2 months 3 weeks ago
#4184
Gigabyte Z590 Vision D with dual I225-V
My problem is that one of both controllers intermittently drop out with "Windows has stopped this device because it has reported problems. (Code 43)". Disabling the device and reenabling it brings it back for a while.
Rolled back driver to 2.1.1.7 (the latest on the Gigabyte site for this board) but still have the same problem. Thought a firmware update might help.
Followed procedure given till:
C:\I225V>EEUPDATEW64e.exe /nic=1 /d NVM\FXVL_15F3_V_1MB_1.89.bin
EEUPDATE v5.38.10.00
NIC Bus Dev Fun Vendor-Device  Branding string
  1   4  00  00   8086-15F3    Intel(R) Ethernet Controller (3) I225-V
  2   5  00  00   8086-15F3    Intel(R) Ethernet Controller (3) I225-V
Writing SHARED FLASH.  PLEASE DO NOT INTERRUPT THIS PROCESS.
  1:  Shared Flash image update FAILED! Timeout Error
EEPROM Image Version: 1.57
Any suggestions?
#4185
Try the latest drivers and if that doesn't work try under Windows PE
Station-Drivers - Comment creer une clé bootable Windows
  • John167989
  • John167989's Avatar
1 month 5 days ago
#4439
Before update my pcie i225v firmware, i made a back files using this command: EEUPDATEW64e.exe /nic=1 /DUMP and i got 2 files: .bin (2MB) and .eep.
the update failed, now i can not use it at all:
EEUPDATEW64e.exe /nic=1 /eepromver:
  1   4  00  00   8086-15FD    Client Foxville with Empty Flash
 1: EEPROM Image Version: 2.DA
when i try to restore the old bin i get an error: EEUPDATEW64e.exe /nic=1 /FORCE /DATA dump.bin
  1:  Image size larger than flash size, aborting!
any solution ? im stuck.
  • QuadDamage
  • QuadDamage's Avatar
1 month 5 days ago - 1 month 5 days ago
#4440
If your card changed PID to 15FD, it means that i225's memory chip is empty. Any dump of eeprom or bin will contain useless random data. You said that you have old backup. Eeupdate tool has a bug that generates double-backup for 1M cards. Run any hex editor and delete second half of the backup. Leave area from 0x0 to 0xfffff (1MB).
Flash that file by simply command:
eeupdate /nic=1 /d backup_1mb.bin
Then turn AC OFF for 30 seconds. Wait till all LEDs will turn off on the motherboard.
The eeupdate bug generates 2MB backup for 1M cards like shown:
If your backup is corrupted, write to me. I can do anything with those cards with my magic
i225v@outlook.com
Last edit: 1 month 5 days ago by QuadDamage.
  • John167989
1 month 4 days ago
#4441
i225v@outlook.com
i sent you an email, thanks a lot.
