Hello everyone,
Fdrsoft
  • Adrian
  • Adrian's Avatar
  • poster 5
  • poster 5
#1794
Hello, please help me, I have a msi z690 torpedo with intel I225-V and I upgraded the network card, but after the restart it doesn't see it anymore and the backup made DOESN'T WORK RESTORED WHAT SHOULD I DO WITH THE BOARD??
Writing SHARED FLASH.  PLEASE DO NOT INTERRUPT THIS PROCESS.
  1:  Shared Flash image update FAILED! Pointers in Shadow RAM are corrupted
I tried to update the bios but it still doesn't see it in the device manager, and if I put another driver version it still doesn't work, what can I do??
Intel I225-V Ethernet Controller 28.0 this wil tell me the adaptor is disabled, you must be enable
I managed to do it, I upgraded the chip, but I tried everything from the NVM folder  FXVL_15F2_LM_1MB_1.89.bin with this it was activated from disable to enabled and then I flashed FXVL_15F3_V_1MB_1.89.bin and shut down the PC for 30 seconds unplugged now rev 03 appears from rev 02 as if it was, I thought it was broken and I was thinking of sending it for the motherboard warranty
Last edit: 1 year 6 months ago by Adrian.
1 year 6 months ago
#1800
Hi yes, check that the chipset is the correct one because there are two versions LM or V
  • Adrian
  • Adrian's Avatar
  • poster 5
  • poster 5
1 year 6 months ago
#1801
www.msi.com/Motherboard/MAG-Z690-TORPEDO/Specification
1x Intel® I225V 2.5Gbps LAN controller
1 year 6 months ago
#1802
Everything works well ?
  • Woozie
  • Woozie's Avatar
1 year 6 months ago
#1804
Hello,
In recent months Intel said they released 1.93 NVM. At least for I225-V. Can you find it and share it please?
