1 year 7 months ago
#1445
Hi, have you updated the latest drivers from the Version 28.2 package if so try to do a speedtest then display it to see the ping
  • Alexander
  • Alexander's Avatar
1 year 7 months ago
#1448
If it's that happening it's not related to firmware. In my case it fixed weird issue witch v.2.1.3.3 with WoL (not working) and/or error "Unreachable host" (if WoL worked at certain moment). I have been using much older driver  1.1.3.34  or 1.1.4.38  wich is not necessarely bad, instead it solved any issue.  .  Even Microsoft drivers does the job. Anyway. Anyway i just spoted a new version 3.1.1.15 for Intel I225/I226 that comes witch latest Network Coonection Software 8.2 (i usually don't care about it, most of releases dont't upgrade drivers for most LAN devices).
If you a certain that something witcked is happening with the LAN card then uprade to v.2.1.3.15 if you haven't or downgrade to  v.2.1.3.3 if you already have upgraded. I just upgraded now the drivers, gonna testing to see for abnormal pings/jitter/bandwith on some Benchmarking Servers and CS ones.
#1450
Me personally no worries with Version 1.89 and Version 1.68 (see below)
I225-LM Rev 3.x        I225-LM Rev 1.x
Last edit: 1 year 7 months ago by admin.
  • Edmarts
  • Edmarts's Avatar
1 year 7 months ago
#1454
Good evening everyone!
My Asus B650E-E has the I225V 3V LAN and had the 1.8x firmware... any online game with 1 minute open made the connection drop.
I did the procedure and updated the firmware to the most up-to-date version, but the card remains with the same behavior.
Can anyone help me?
  • Edmarts
  • Edmarts's Avatar
1 year 7 months ago
#1455
A question: Can I take the dump of another card of the same chipset and write to my ethernet controller?
