Hello everyone,
Fdrsoft
  • Vitaliy
  • Vitaliy's Avatar
#1377
Hello.
I got on Amazon "Midautoo I225-V Network Card"
PCI\VEN_8086&DEV_15F3&REV_01
I try to update firmware with no success :(
That what I have
EEUPDATE v5.38.10.00
NIC Bus Dev Fun Vendor-Device  Branding string
  1   2  00  00   8086-15F3    Intel(R) Ethernet Controller I225-V
 1: EEPROM Image Version: 1.36
C:\Temp>EEUPDATEW64e.exe /nic=1 /DUMP
 1: Writing EEPROM image to file '1CFD0876A607.eep'...Done.
NO .bin created.
C:\Temp>EEUPDATEW64e.exe /nic=1 /d NVM\FXVL_15F3_V_1MB_1.89.bin
  1:  Image size larger than flash size, aborting!  :(
Driver date 2/9/2023
Driver version 1.1.4.38
Last edit: 1 year 8 months ago by Vitaliy.
1 year 8 months ago
#1379
Hi, I had the same problem I believe that the additional cards do not include NVM party
  • Vitaliy
  • Vitaliy's Avatar
1 year 8 months ago
#1382
Hi.
Is here anything I can do with this card except of returning it?
1 year 8 months ago
#1383
why it doesn't work ?
  • Vitaliy
  • Vitaliy's Avatar
#1391
It shows 1Gb max. Much slower then onboard 1Gb and periodicly stops working.(No light). Only restart helps.
It has "P25Q16H Ultra Low Power, 16M-bit Serial Multi I/O Flash Memory" on board. Why it does not want to read and write it?
