Hello everyone,
Fdrsoft
1 year 10 months ago
#1184
Impec
  • Districtor
  • Districtor's Avatar
1 year 8 months ago - 1 year 3 months ago
#1309
Asus ROG MAXIMUS XIII HERO 2 x Intel I225-V
The first NIC updated fine from 1.68, the second NIC update hung for over an hour, so i had to terminate via Task Manager.
Now, if I try to flash 1.89 I get the message: Shared Flash image update FAILED! Pointers in Shadow RAM are corrupted.
The same message with the backup dump.
nvmupdatew64e.exe -i -l yourlogname.log for the second NIC:
[00:007:00:00]: Intel(R) Ethernet Controller (3) I225-V
    Vendor                 : 8086
    Device                 : 15F3
    Subvendor              : 8086
    Subdevice              : 0000
    Revision               : 3
    LAN MAC                : 000000000000
    Alt MAC                : 000000000000
    SAN MAC                : 000000000000
    ETrackId               : 00000000
    SerialNumber           : F02F74FFFFCB1xxx
    NVM Version            : N/A(N/A)
    PBA                    : N/A
    VPD status             : Corrupted
    VPD size               : 0
    NVM update             : No config file entry
      checksum             : Invalid
EEUPDATE:
 2: EEPROM Image Version: Unversioned
Device Manager:
This device cannot start. (Code 10)
STATUS_DEVICE_POWER_FAILURE
NIC Driver:
2.1.3.3
Now I know, the second NIC is most likely bricked, but has anyone any ideas how to fix this?
Last edit: 1 year 3 months ago by Districtor.
  • Districtor
1 year 8 months ago
#1310
Nevermind, fixed it by using nvmupdatew64e with the -f (force) command.
  • EDU5K
  • EDU5K's Avatar
#1320
hi i have asus b550-e win 10 21h2 19044.3086 Intel I225-V Rev 2 driver 1.1.4.38 NVM version of the NIC is 1.69(1.45) can i update without problems?
Last edit: 1 year 8 months ago by EDU5K.
1 year 8 months ago
#1325
Hi, yes no problem normally, make a backup of the firmware before
