  • Ataemonus
  • Ataemonus's Avatar
1 year 8 months ago
#1412
What chip used? V or LM. I read 226V has same bug as 225V :(
Given that the V version is only made to be integrated opn motherboards because it communicates directly with the chipset, guess which one it is :-)
  • Vitaliy
  • Vitaliy's Avatar
1 year 8 months ago
#1413
Me they are i225-LM and yes cerla key affects the version just the Rev 3.0 is not affected a priori
I did not get. It is I226 written in board description. Do you have this board? Is it V or LM?
1 year 8 months ago
#1416
No i225-LM only
  • Vitaliy
  • Vitaliy's Avatar
1 year 8 months ago
#1418
What chipset has board you gave link to Aliexpress?
1 year 8 months ago
#1419
Intel i226-LM
