- Alien Invader
TiX which mainboard you have ? It seems to me that you are connected to a 5Gbit port, the name for 10Gbit should be different on chipgenius as I have the same 5Gbit connection and same HIGH SPEED indication.
My screenshot is with a M2 SATA on USB 3.0 5Gbit port (Z97)
*As the 2nd image says USB 3.2 Gen1 is in fact 5Gbit so the speed you have is pretty normal. The 10Gbit ones are called 3.2 Gen2.
Last edit: 3 years 3 months ago by Alien Invader.
- kufa
For anyone who has this case, I've written an answer file that works perfectly for it.
Inateck FE2025
Inateck.cfg
;Configure Start
U2PHY = 02 f4 9b e0 e1
U3PHY = 02 d4 09 00 d5 00 80
VID = 0xbda
PID = 0x9210
MANUFACTURE = "Inateck"
PRODUCT = "FE2025"
SCSI_PRODUCT = "RTL9210B NVME"
SCSI_VENDOR = "Realtek"
;SN von Gehäuse anpassen - Adjust SN of Enclosure
SERIAL = "2F22AKA1"
DISK_HOTPLUG = 0x0
LED = 0x2
PINMUX1 = 0x0
PINMUX2 = 0x0
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x0
ASPMDIS = 0x0
;Anpassen mit aus (false) oder Zeit in minuten. z.b. 10
;Adjust with off (false) or time in minutes. E.g. 10
DISK_IPS_THRES = false
;EN_UPS = n/a
;PD = n/a
HW_LED_CFG = false
CUSTOMIZED_LED is 15 bytes = 0x80000081
CUSTOMIZED_LED = 07 00
SUSPEND_LED_OFF = 0x0
FAN = false
DIS_SHOW_EMPTY_DISK = false
FORCE_SATA_NORMAL_DMA = false
UART_DBG_PIN = 0x5
FINGER_PRINT_EN = false
DISCONN_FORCE_USB2 = 0x0
FORMAT_DISK = n
INC_SERIAL = false
;PARTITION: GPT, MBR
PARTITION = "GPT"
;FORMAT: NTFS, exFAT
FORMAT = "exFAT"
LABEL = "Inateck m2"
Boot Mode = false
FW Ver = 1
FW Build Date = 2023
IC Ver = 0xa0010002
Disconn_ForceUSB2 = 0x0
Inateck FE2025
Inateck.cfg
Warning: Spoiler!
;Configure Start
VID = 0xbda
PID = 0x9210
PRODUCT = "FE2025"
SERIAL = "2F22AKA1"
DISK_HOTPLUG = 0x0
LED = 0x2
PINMUX1 = 0x0
PINMUX2 = 0x0
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x0
ASPMDIS = 0x0
;EN_UPS = n/a
;PD = n/a
HW_LED_CFG = false
FAN = false
UART_DBG_PIN = 0x5
FORMAT_DISK = n
INC_SERIAL = false
PARTITION = "GPT"
FORMAT = "exFAT"
Boot Mode = false
FW Ver = 1
IC Ver = 0xa0010002
- TiX
3 years 3 months agoUsing a MSI katana gf66 notebook the mainboard is "msi MS-1584"TiX which mainboard you have ? It seems to me that you are connected to a 5Gbit port, the name for 10Gbit should be different on chipgenius as I have the same 5Gbit connection and same HIGH SPEED indication.
" Using a MSI katana gf66 notebook the mainboard is "msi MS-1584" "
If your box is well connected in USB 3.2, try to see if your disk, what model is it?
Otherwise you can try to update but I don't know if that solves your problem, to see
