  • Alien Invader
  • Alien Invader's Avatar
MSI GF66 spec says 1x Type-C USB3.2 Gen1 which means 5Gbit port. There is no USB 10Gbit support on your laptop.
3.2 Gen1 -> 5Gbit (Same as 3.0 / 3.1 Gen1)
3.2 Gen2 -> 10Gbit
3.2 Gen2x2 -> 20Gbit
Last edit: 3 years 3 months ago by Alien Invader.
The following user(s) said Thank You: admin, dmitry
Alien Invader it can work but on the USB-C port but not sure it works in 10Gbps
in USB 3.2. Gen1 this is a bit tricky because not clear on the sites
Quelle est la différence entre USB 3.1 Gen 1, Gen 2 et USB 3.2 ? - Kingston Technology
USB 3.2 Speed Comparison & Real-world Performance (everythingusb.com)
Last edit: 3 years 3 months ago by admin.
Alien Invader Not easy to know exactly the possibilities of the 3.2 chipset (Gen 1 or Gen 1x1)?
  • Alien Invader
If one thing is certain thats the crappy naming of USB after 3.0, they made it even worst now with USB4 just go ahead and check. As for the speed issue I think MSI on their website ( MSI GF66)
says it clearly that the laptop has only 5Gbit USB ports.
Alien Invader thank you for the info but it's to tear your hair out with it's USB 3.2 standard. xxxxxxxxxx bullshit
