3 years 9 months ago - 6 months 3 weeks ago
 Restoration Topics Old Forum
created by  sdefrwggerg
it´s for both RTL9210 and RTL9210B Chipsets dumped the current fw info with MPTool, made sure to change all parameters in *.cfg file RTL9210B_CG_Lite.cfg to match the original fw dumped info and finally commented the DISK_IPS_THRES entry.
Fideco,Orico..
1. Remove nvme from enclosure.
2. Fw update to latest firmware your rtl9210 enclosure see above for latest fw and cfg file.
3. Update to latest firmware your nvme m.2 using a pcie pc slot see nvme manufacturer app.
4. Reinsert nvme to enclosure and be happy.
Version 1.29.8 for A and B
IC Ver : 0xa0010001 is A
IC Ver : 0xa0010002 is B
Find a Chip on the board that is small and has 2x3 mm aspect ratio and on the top is printed P25Q40SH or FM25Q04A or PUYA P25D40H. Search for the Datasheet of it look for CS# and VCC Pin or CS# and Hardware Reset Pin in Datasheet description of Pin Configurations. There is a Hard Reset Procedure on Rom in case of bricking your device. You need to short pins 1 & 8 with tweezers then connect to USB port for 10 seconds (until you hear a ding) and then remove the tweezers (unshort) while it still plugged in and flash a working Rom via USB from here. This will force RTL9210 to start with internal ROM, not with external f/w in SPI flash.
Last edit: 6 months 3 weeks ago by admin.
The following user(s) said Thank You: pipes80@live.it, djmaniac44
 by  sdefrwggerg
Replied by  sdefrwggerg  on topic  NVME USB drives Realtek RTL9210B / RTL9210 Firmware v1.23.9
re-uploaded  here
Settings for ORICO M2PJM-C3 Update from FW Ver : 1.18.12 FW Build Date : 2019.11.19 to:
MANUFACTURE : "External"
PRODUCT : "M.2 NVME"
SERIAL : "012345678903"
SCSI_PRODUCT : "M.2 NVME"
SCSI_VENDOR : "External"
DISK_HOTPLUG : 0x00
PINMUX1 : 0x00070000
PINMUX2 : 0x00000000
DISK_IPS_THRES : 0x01
CUSTOMIZED_LED : n/a
FAN : 0x00000000
DIS_SHOW_EMPTY_DISK : 0x00
UART_DBG_PIN : 0x00
RM_INTERNAL_RD : 0x00
EFUSE :
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F0 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Boot Mode : Flash NM
FW Ver : 1.23.9
FW Build Date : 2020.10.05
IC Ver : 0xa0010001
IC Pkg Type : PCIE
par  Galixte
Réponse de  Galixte  sur le sujet  NVME USB drives Realtek RTL9210B / RTL9210 Firmware v1.23.9
On this page : [url][/url]  plugable.com/products/usbc-nvme   I found a firmware revision for  RTL9210  which is doesn’t available here on Station-Drivers: 1.27.5 (december 2021).
Download: [url][/url]  media.plugable.com/downloads/drivers/pro...ekfirmware202112.zip
Release notes:
Released December 2021This firmware update aims to improve stability with Samsung 980 Pro and Western Digital SN550 NVMe SSDs.The power LED behavior is also improved on Windows, and Intel based Mac systems: now when safely ejected the power LED should turn off ( it may blink slowly ) indicating the drive may be safely unplugged from the computer.This update is recommended for uses who have experienced connectivity problems with Samsung 980 Pro or Western Digital SN550 NVMe SSDs.
I’ve tried to add it manually but it doesn’t work. Is there any problem to submit new file on Station-Drivers?
@admin Could you add this, please?
Seehank
Galixte post=6142 userid=5274On this page:   plugable.com/products/usbc-nvme   I found a firmware revision for  RTL9210  which is doesn't available here on Station-Drivers:  1.27.5 (december 2021).
Download:   media.plugable.com/downloads/drivers/pro...ekfirmware202112.zip
Unfortunately it does not seem to have files for RTL9210B in it.
