  • TheDoomSlayer
  • TheDoomSlayer's Avatar
3 years 5 months ago
Hello, I have an ORICO-BM2C3-G2 enclosure (10Gbps), the chip is RTL9210 with no letters. Wich firmware and config should I use?
The problem is, it was not working with my laptop. I tried updating it with several firmwares from this topic, with most of them it is recognized by laptop but works on usb 2.0 speed only. I have eventually installed 1.25 and it seems to work fine, speeds are not geat though (400 MB/s read). So I'd like to try something newer, could anyone please help?
  • spike_V_sky
  • spike_V_sky's Avatar
@TheDoomSlayer
hi
I think you should double check if you enclouser use RTL9210B RTL9210BA(A or B).
Here there is a contacts from orico, i suggest you to send an email for a request.
From orico you should request the original firmware where you can find the config file for your device.
Last edit: 3 years 5 months ago by spike_V_sky.
The following user(s) said Thank You: TheDoomSlayer
Hi all,
I allow myself to add that certain USB-C cable provided does not sound efficient to be able to have 10Gbs so try with another USB 3.2 cable (10Gbs) and also check that you are on a USB 3.2 port
  • TheDoomSlayer
@spike_V_sky
Thank you for your reply, I already sent an email to Orico before posting here.
This is my controller, is it A or B?
P.S.: I am not expecting it to perform at 10Gbps, I just need a suitable stable firmware
Last edit: 3 years 5 months ago by TheDoomSlayer.
  • Machi007
  • Machi007's Avatar
@xz Thank you maybe you can ask Support why an old GD firmware was used
Hi sdefrwggerg,
can you please share your Config File RTL9210_VB_CG_Orico_0m2.cfg ?
I can't find it anywhere.
I have Orico SSD enclosure and I want to upgrade to newest FW :-)
