- taiduc94@gmail.com
4 months 4 days ago
sadly, still fail! What‘s a bad day.
4 months 4 days ago
Try without the disk then do an update again, it is possible that the disk is preventing the update
Same with another USB-C cable
4 months 4 days ago
already try that, and it‘s still failed
3 months 3 weeks ago - 3 months 3 weeks agoI updated the firmware earlier on my Hagibis enclosure it made no difference still benchmarking 1500-1600 MB/s still saying Gen2x2
Then i remembered i ordered a short 40Gbps cable so used that cable instead of the one that came with it
its Gen3x2 now ...
Flashing the latest firmware broke the dual led's of the enclosure but whatever
i will fix that at a later date by harassing hagibis harder for a firmware update
Last edit: 3 months 3 weeks ago by Shonk.
Hi Shonk, with my SSD and the latest firmware I can't reach write speeds beyond 3xxx but I'm sure it's the SSD that must be incompatible, there's still work to be done with the firmware to extend compatibility.
Last edit: 3 months 3 weeks ago by admin.
