#3561
weird because even with my antivirus no problem under Windows 11
Last edit: 6 months 2 weeks ago by admin.
  • Laroldski's Avatar
#3562
@opoetasantoza Try updating it on another Laptop or PC and if that doesn't work try shorting the 2 pins to reset the chip and restore it back to the original firmware incase that's the problem.
@admin Can you post a link to the article on how to unbrick your RTL9210 chip and the ASMedia chips,I think this may help the poster as it did me one time with the same problem.
#3563
VBS MAYBE?
  • opoetasantoza
  • opoetasantoza's Avatar
#3564
How to Short These Pins ?
  • opoetasantoza
#3565
How to Short These pins ?
