  • CaBrAcHo83
  • CaBrAcHo83's Avatar
6 months 2 weeks ago
#3553
Thanks for the info but still the "Failed" message on my side🥲
#3554
try plugging it into a usb 2.0 or 3.0 port because I had a crash and I managed to update it to USB 3.2 instead of my Thunderbolt port
  • opoetasantoza
  • opoetasantoza's Avatar
#3557
My Drive dont recognise on mptool, any ideia ?
#3559
Try on a USB 2.0 port because maybe some controllers are not supported by the MPTOOL
  • opoetasantoza
#3560
I tryed on old laptop and get same error
