Asmedia ASM2464 NVME/USB 4.x Controller Firmwares
8 months 1 week ago - 5 months 2 weeks ago
#3183
(fanxiang SSD NVMe 2To SSD M.2 PCIe Gen 3x4 2280 Disque SSD Interne 1To, Jusqu'à 3500Mo/s en Lecture, 3000Mo/s en Écriture )
www.station-drivers.com/index.php/en/com...17_85_00/lang,en-gb/
Last edit: 5 months 2 weeks ago by admin.
#3334
Im considering pickup up an asm2464 as they are quite cheap atm £28+ vat my laptop has tb4
its hard to find the usb 3.x speeds for other devices
do they support 3.2 gen2 x 2?
do they support 3.2 gen2 x1?
i have looked through the documentation included with the firmware and it looks like it does
but would like to confirm before i order it later tonight
Last edit: 7 months 2 weeks ago by Shonk.
#3335
I confirm because I have 2 USB 3.2 Gen2 x2 ports, no problem but performance down compared to Thunderbolt 4 but normal ts hard to find the usb 3.x speeds for other devices do they support 3.2 gen2 x 2?
www.station-drivers.com/index.php/en/for...oller-firmwares#2673
Last edit: 7 months 2 weeks ago by admin.
#3338
thanks
I ended up paying £32.44 for it delivered
7 months 6 days ago
#3391
It turned up earlier
feels well made and has the latest firmware
my laptop seems locked at gen2 though for some reason
