6 months 4 weeks ago - 6 months 4 weeks ago
#3505
Are you sure that your chipset is an ASM2362 or rather 2464 because the firmware is for the 2464
Have you tried directly in USB 2.0 for the update because sometimes the USB3.x port poses problems
Last edit: 6 months 4 weeks ago by admin.
  • CaBrAcHo83
  • CaBrAcHo83's Avatar
#3506
Thanks for the advice, I also tried in USB 2.0, still the same "Failed"...
[img
[img
Last edit: 6 months 4 weeks ago by CaBrAcHo83.
  • CaBrAcHo83
6 months 3 weeks ago
#3508
The reseller of the box which is ORICO answered me by specifying:
Hello, dear friend, this is a problem of the firmware version. In general, it cannot be modified at will. Even if the original is modified, it will not be used.
So I deduce that there is surely a protection on this version to avoid modifying the firmware
#3510
It is possible yes that it is restricted it is quite rare
#3551
New Asmedia ASM2464 NVME/USB 4.x Controller Firmware Version 240703_85_00
ASM-2464 NVMe/USB 4.x Controller (40Gbps) (station-drivers.com)
Last edit: 6 months 2 weeks ago by admin.
