5 months 2 weeks ago
I think the included version should do it can you confirm (AS_USB4_240913_00_00_00.bin)
- Galixte
- regular poster
5 months 2 weeks ago - 5 months 2 weeks agoOui avec le dernier firmware du boitier ASM2464PD et la mode CrystalDiskMark « NVMe SSD » cela donne cela de mon côté :
Last edit: 5 months 2 weeks ago by Galixte.
- Galixte
- regular poster
5 months 2 weeks agoLooking at the chipmaker’s website , there aren’t many differences:see below..
- The “X” version supports configuration of the four PCIe lanes to support up to four devices at once. The lanes can be configured as a single 4-lane device, two 2-lane devices, four 1-lane devices, or a 2-lane device and two 1-lane devices.
- The “X” version can support an external power-delivery controller chip (in case the built-in one is not sufficient for the product).
yeah it was just me miss remembering something
Thinking ASM2464PD was ASM2464
and ASM2464PDX was ASM2464PD
my bad
my bad
- taiduc94@gmail.com
4 months 1 week ago
Happend when i tried to upgrade, and then my Maiwo k1717 only run at usb gen 3x1, speed limit to 10gbs. please help. Can not upgrade, fail all the time.
