4 months 1 week ago - 4 months 1 week ago
#3976
Hi Try plugging it into a usb 2.0 port for the update
Last edit: 4 months 1 week ago by admin.
  • taiduc94@gmail.com
  • taiduc94@gmail.com's Avatar
4 months 1 week ago
#3977
Still failled, but the progress came up a little, before it was fail at 12%, and now fail at 18%
4 months 1 week ago
#3978
Try another version and only take the version ending with 85.xxxxx
4 months 1 week ago
#3979
i'm sorry, but still the same. i'm hopeless.
4 months 1 week ago
#3980
It still works otherwise try to do a reset as below
