il y a 2 ans 1 mois
it must have come with a bad nvram then (cfg)
il y a 2 ans 1 mois
Ofc you can i customize all of mine for the drive actually in there and its actual serial number and such
Here's one as an example
;Configure Start
U2PHY = 02 f4 9b e0 e1
U3PHY = 02 d4 09 00 d5 00 80
VID = 0xbda
PID = 0x9210
MANUFACTURE = "Samsung"
SCSI_VENDOR = "Samsung"
PRODUCT = "Samsung SSD PM9A1 1TB"
SCSI_PRODUCT = "SSD PM9A1 1TB"
SERIAL = "S641NX0TB24240"
DISK_HOTPLUG = 0x0
PINMUX1 = 0x70000
PINMUX2 = 0x0
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x70
ASPMDIS = 0x0
;SUSPEND_DISK_OFF = 1
DISK_IPS_THRES = 10
;EN_UPS = 0x0
;PD = 0x0
LED = 0x1
;HW_LED_CFG = 0x0
;CUSTOMIZED_LED is 15 bytes
;CUSTOMIZED_LED = 01 01
;SUSPEND_LED_OFF = 0x0
;FAN = 0x0
;DIS_SHOW_EMPTY_DISK = 0x1
;FORCE_SATA_NORMAL_DMA = 0x0
UART_DBG_PIN = 5
;FINGER_PRINT_EN = n
;DISCONN_FORCE_USB2 = n
FORMAT_DISK = n
;INC_SERIAL = y
;PARTITION: GPT, MBR
PARTITION = "MBR"
;FORMAT: NTFS, exFAT
FORMAT = "NTFS"
LABEL = "My USB"
Les utilisateur(s) suivant ont remercié: pt83
- pt83
il y a 2 ans 1 moisI want to add GUID is that possible? Orico Box a few years ago do have GUID but newer one doesn't have. Which is needed for my UnraidOS to accept the license linking.Ofc you can i customize all of mine for the drive actually in there and its actual serial number and such
- yasins
- Membre
il y a 2 ans 1 mois
Hello! Please file send to me
E-Mail will be to sent PM
E-Mail will be to sent PM Connexion ou Créer un compte pour participer à la conversation.
- yasins
- Membre
il y a 2 ans 4 semaines - il y a 2 ans 4 semaines
Good day, Is it possible to change the IC Pkg Type section of the box and get SATA feature in the box? Is such a thing possible? There is also Realtek rtl9210b-CG SATA support, which is normally found on the box., so I set the firmware to 1.33.44. Model : M2PV-C3
PRODUCT : "Realtek"
SERIAL : "012345678909"
SCSI_PRODUCT : "RTL9210B-CG "
DISK_HOTPLUG : 0x00
LED : n/a
PINMUX1 : 0x00000000
PINMUX2 : 0x00000000
DISK_IPS_THRES : 0x00
CUSTOMIZED_LED : 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00
SUSPEND_LED_OFF : 0x01
FAN : 0x00000000
HS_AUTO_SWITCH : 0x05
SUSPEND_DISK_OFF : 0x01
FW Ver : 1.33.44
FW Build Date : 2024.01.18
IC Pkg Type : PCIE
Temps de génération de la page : 0.029 secondes
