- Blast Beat
il y a 2 ans 2 semaines
Hello everyone,
i got an enclosure JEYI i9GTR-2280 bought on Aliexpress with a RTL9210 chip and a very old firmware v1.21.17.
The goal is to flash v1.29.12.
Windows see the enclosure as RTL9210 but on the pcb i can read 9210B.
This is my dump file, can you please edit it?
Device : [Port7] : Realtek RTL9210 NVME #0
U2PHY : 02 f4 9b e0 e1
U3PHY : 02 d4 09 00 d5 00 80
PRODUCT : "RTL9210"
SERIAL : "012345679060"
DISK_HOTPLUG : 0x00
PINMUX1 : 0x00070000
PINMUX2 : 0x00000000
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : n/a
UART_DBG_PIN : n/a
FP_UART_BAUD_RATE : n/a
EFUSE :
FW Ver : 1.21.17
FW Build Date : 2020.04.14
IC Pkg Type : PCIE
Disconn_ForceUSB2 : 0x00
- Absent
Hi ,on the definition that Windows detects it does not matter whether it is a RTL9210 or 9210B because you can name it whatever you want as mine is an Asus TUF A1
Les utilisateur(s) suivant ont remercié: Blast Beat
- Blast Beat
OK so to go forward can i use the text below as config file named RTL9210B_CG_Lite.cfg ?
I am asking because MpTool v1.12 in the zip file leave almost everything locked
;Configure Start
PRODUCT : "RTL9210"
DISK_HOTPLUG : 0x00
UART_DBG_PIN : n/a
EFUSE :
FW Ver : 1.29.12
FW Build Date : 2022.11.01
IC Pkg Type : PCIE
;DISCONN_FORCE_USB2 = n
FORMAT_DISK = n
;INC_SERIAL = y
;PARTITION: GPT, MBR
PARTITION = "MBR"
;FORMAT: NTFS, exFAT
FORMAT = "NTFS"
LABEL = "My USB"
il y a 2 ans 2 semaines - il y a 2 ans 2 semaines
@Blast Beat download the file from this link it is the original file that you are looking,it is the configure file for the JEYI i9GTR [url]
www.sendspace.com/file/uhxw85
[/url]
Sorry for the double post I did not mean to do that.
- Blast Beat
Thnks you
Laroldski
I download the latest file for the version "A" here
Realtek RTL9210(A-
NVMe/USB 3.1 Controller firmware Version 1.30.21.070622
There was already in the configure folder a file named jeyi.cfg, i edit it just with my serial, than i used UTHSB MPtool Lite V1.14.8.0610 present in the main folder and full unlocked as you can see in the image attached.
From my point everything was right, i toke off the ssd, i switched off even the windows antivirus.
Few second after i started the update, i got an alert from the os (Win 11) of unknown device and few second later the flash procedure got error
I bricked my enclosure
Realtek RTL9210(A-
