- djmaniac44
il y a 2 ans 4 jours....
I already downloaded flashing software from [url] github.com/bensuperpc/rtl9210-firmware [/url]
A big shout out and thanks to the guy (Bensuperpc) who made this github collection! This is sooo usefull!
- fhloston
il y a 2 ans 3 jours
Thank you for this collection!
I have an ICY BOX IB-1817MCT-C31 and have verified that my factory config is the same as the supplied IB-1817MCT-C31.cfg.
However after successfully flashing the latest firmware the adapter does not work properly with an INTEL SS DSCKKB480GZ - it is displayed in dmesg, but any attempts in accessing it fail:
Any ideas? Is this adapter just incompatible with this specific SATA device?
NVME devices work fine!
Is the newest firmware not SATA capable?
I do not have any other m.2 SATA device to check.
[56381.288904] sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
[56381.288908] sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 37 e4 33 d8 00 00 28 00
[56381.288910] I/O error, dev sda, sector 937702360 op 0x0:(READ) flags 0x80700 phys_seg 5 prio class 0
[56381.288925] sd 0:0:0:0: [sda] tag#24 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
[56381.288928] sd 0:0:0:0: [sda] tag#24 CDB: Read(10) 28 00 37 e4 32 00 00 00 d0 00
[56381.288930] I/O error, dev sda, sector 937701888 op 0x0:(READ) flags 0x80700 phys_seg 26 prio class 0
[56381.288939] sd 0:0:0:0: [sda] tag#25 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
[56381.288942] sd 0:0:0:0: [sda] tag#25 CDB: Read(10) 28 00 37 e4 32 d8 00 00 08 00
[56381.288943] I/O error, dev sda, sector 937702104 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[56381.288949] sd 0:0:0:0: [sda] tag#26 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
[56381.288951] sd 0:0:0:0: [sda] tag#26 CDB: Read(10) 28 00 37 e4 32 e8 00 00 10 00
[56381.288953] I/O error, dev sda, sector 937702120 op 0x0:(READ) flags 0x80700 phys_seg 2 prio class 0
[56381.288958] sd 0:0:0:0: [sda] tag#27 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
[56381.288960] sd 0:0:0:0: [sda] tag#27 CDB: Read(10) 28 00 37 e4 33 00 00 00 20 00
[56381.288962] I/O error, dev sda, sector 937702144 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 0
[56381.288968] sd 0:0:0:0: [sda] tag#28 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
[56381.288971] sd 0:0:0:0: [sda] tag#28 CDB: Read(10) 28 00 37 e4 33 28 00 00 a8 00
[56381.288973] I/O error, dev sda, sector 937702184 op 0x0:(READ) flags 0x80700 phys_seg 21 prio class 0
[56381.288986] sd 0:0:0:0: rejecting I/O to offline device
[56381.288999] I/O error, dev sda, sector 937701888 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[56381.289008] Buffer I/O error on dev sda, logical block 117212736, async page read
- Shenanigans
il y a 2 ans 2 jours - il y a 2 ans 2 jours
So I bought an Ugreen device from amazon, with the dump below.
Updated it to the newest firmware from this awesome repository github.com/bensuperpc/rtl9210-firmware 1.33.44.011824, using the config file for Ugreen from there. In the config file I changed the serial number to the right serial number. Or was I supposed to use my dump as a config file?
After that it works, I can format the drive but there is no smart data displayed and the drive name is just n/a.
I guess I messed something up? Thanks for any help!
Edit: With Crystal Disk Info I can display the smart data of my WD Drive !? But I can not display the smart data with windows drive management and the WD Dashboard Software doesn't recognizw the drive. Very strange.
Device : [Port5] : Realtek RTL9210 #0
MANUFACTURE : "Ugreen"
PRODUCT : "Ugreen Storage Device"
SERIAL : "01293805B2F4"
SCSI_PRODUCT : "n/a"
SCSI_VENDOR : "n/a"
DISK_HOTPLUG : 0x01
PINMUX1 : 0x00000000
PINMUX2 : 0x00000000
DISK_IPS_THRES : 0x0f
CUSTOMIZED_LED : n/a
FORCE_USB_QUIRK : 0x00000080
DIS_SHOW_EMPTY_DISK : 0x01
FORCE_SATA_NORMAL_DMA : 0x01
FW Ver : 1.29.38
FW Build Date : 2022.04.25
IC Pkg Type : PCIE
- AOnurY
- Membre
Completely delete the SCSI PRODUCT: "n/a" and SCSI VENDOR: "n/a" lines in the configuration file and flash again.
setting ; in the ini for SCSI_VENDOR or SCSI_PRODUCT just makes the drive pull the id from the drive for them
e.g. it passes through the data from the drive and is how Ugreen set the ini at the factory
Example
MANUFACTURE = "INTEL"
;SCSI_VENDOR = "INTEL"
PRODUCT = "MEMPEK1J016GA"
;SCSI_PRODUCT = "MEMPEK1J016GA"
his U2PHY and U3PHY at n/a is odd
Example
Les utilisateur(s) suivant ont remercié: Shenanigans
