2 months 12 hours ago - 2 months 3 hours ago
For:
VID=0x1D6A, DID=0x04C0 (AQC-113)
VID=0x1D6A, DID=0x14C0 (AQC113C)
VID=0x1D6A, DID=0x94C0 (AQC113CS)
Firmware For Windows
Release note:
- Sets hysteresis to 50 mV.
Feel free to leave a comment
Last edit: 2 months 3 hours ago by admin.
  • d5aqoep
  • d5aqoep's Avatar
  • poster 5
  • poster 5
2 months 10 hours ago - 2 months 10 hours ago
Last edit: 2 months 10 hours ago by d5aqoep.
The following user(s) said Thank You: admin, jumpy76
  • jumpy76
  • jumpy76's Avatar
2 months 6 hours ago - 2 months 5 hours ago
Thank you for your answer.
Thank you!
Edit: where did you write your ID? In the configuration section for deviceSupported, and...?
Last edit: 2 months 5 hours ago by jumpy76.
  • d5aqoep
  • d5aqoep's Avatar
  • poster 5
  • poster 5
Yes there.
  • jumpy76
  • jumpy76's Avatar
I get this error, any idea?
[img
