- misal1337
- Poster
5 months 1 week agoThe reflash doesn’t work because the updater does not see the correct four parts ID. So it doesn’t reset the card to start the flashing procedure. Am I missing something?
- jumpy76
5 months 1 week ago
Regarding the integrated cards, do you know if the firmware is included into motherboard bios?
5 months 1 week ago
No, the AQC113 chipset has internal firmware.
5 months 1 week ago
d5aqoep
So the chipset is no longer detected in Windows?
- misal1337
- Poster
5 months 1 week ago
Chipset gets detected in Windows. The card comes up as QNAP QXG card with 2 x 10G Ports but there is an exclamation mark in device manager for both NICs. I can see it's HWID from device manager but the updater fails to fetch the 4 parts ID and is not even able to reset them to begin firmware installation.
