For:
VID=0x1D6A, DID=0x04C0 (AQC-113)
VID=0x1D6A, DID=0x14C0 (AQC113C)
VID=0x1D6A, DID=0x94C0 (AQC113CS)
Firmware For Windows
Release note:
- Sets hysteresis to 50 mV.
Feel free to leave a comment
  • misal1337
  • misal1337's Avatar
  • Poster
  • Poster
Last edit: 5 months 1 week ago by misal1337.
The following user(s) said Thank You: admin, jumpy76
  • jumpy76
  • jumpy76's Avatar
Thank you for your answer.
Thank you!
Edit: where did you write your ID? In the configuration section for deviceSupported, and...?
Last edit: 5 months 1 week ago by jumpy76.
  • misal1337
  • Poster
  • Poster
5 months 1 week ago
Yes there.
  • jumpy76
  • jumpy76's Avatar
5 months 1 week ago
I get this error, any idea?
[img
