  • SystemFailure
  • SystemFailure's Avatar
3 months 2 weeks ago
Have i use the file AQC113-DirtyWake-Swap_Bx-1.5.38_bdp_aqsign (MDI Swap) ?
It work for me
Tried with the file MDI Normal : AQC113-DirtyWake_Bx-1.5.38_bdp_aqsign.clx
  • Patator
  • Patator's Avatar
What do you mean with MDI swap? I
if you have hard time with English I can also understand French.
  • SystemFailure
In the 1.5.38 archive, there are several firmwares that are differentiated as normal MDI or MDI swap.
Normal MDI doesn't work for me, but MDI swap does.
Try normal MDI if swap doesn't work.
MDI is related to the wiring. I imagine MDI swap corresponds to MDI-X or Auto MDI to take into account the cable or what's connected to your board.
www.fs.com/blog/mdi-vs-mdix-and-auto-mdimdix-basics-62.html
  • Patator
  • Patator's Avatar
3 months 2 weeks ago - 3 months 2 weeks ago
Thanks man, I managed to make it work with Antigua swap 1.5.38.
But now i'm back to square one with constant "network link is lost" and "hardware failure"...
Last edit: 3 months 2 weeks ago by Patator.
2 months 4 weeks ago
