Last edit: 3 years 2 months ago by admin.
The following user(s) said Thank You: ethereal
  • sdefrwggerg
  • sdefrwggerg's Avatar
Last edit: 3 years 2 months ago by sdefrwggerg.
  • ethereal
  • ethereal's Avatar
wade7575, as I've explained, my enclosure is working fine. I only had an issue trying to flash a specific firmware version (the latest available so far). Flashing an older version went fine and my unit was working without issues again.
Thanks anyway for your suggestion.
I missed where you said it is working fine,did you use the right configure file for your enclosure.
Yes, I used the specific config file for the Sabrent EC-SNVE.
  • ethereal
  • ethereal's Avatar
I didn't know about that version.
Today I was able to tinker a bit more with flashing my Sabrent EC-SNVE. I'm a Linux guy so I use a Windows virtual machine for flashing my devices. For my Sabrent, this has been working fine up to firmware version 1.30.17. For versions 1.31.17 and 1.32.16, the flashing process fails. (It's not the MPtool program that comes with these newer firmwares cause with the same program l can flash version 1.30.17 without issues). I've just tried booting my real physical machine with a Windows 11 to Go drive and this time, the firmware flashing process went perfectly.
Thanks all you for your suggestions and support.
Best wishes!
Last edit: 3 years 2 months ago by ethereal. Reason: Mistype
  • sdefrwggerg
Linux can be tricky but you now this package www.station-drivers.com/index.php/en-us/...6.010923/lang,en-us/ have outdated UTGDFW
UTGDFW_B Version: 1.29.21 030422    04.03.2022 older
UTGDFW_B Version: 4.30.23 071922    19.07.2022 newer from jeyi
You can find it her: www.station-drivers.com/index.php/en/for...on-1-xx?start=65#721
Time to create page: 0.089 seconds
