1 year 6 months ago - 1 year 6 months agoOrico m2pv-c3 do you have the dump file? Also, the dump file that came out of the stock box? The warranty company did not accept the problem. Now it's just me and my boxIs ugreen cm559 good?
I didn't make a back up copy of the dump file for my Orico m2pv-c3 enclosure because I already had a massive collection of RTL9210 dumps from the uploads that are on station drivers.
Do not worry it is the correct dump file for your enclosure I compared the dump file that was installed in my enclosure to that dump file and checked every line and they are both same.
I have also used the configure file that I will send you with own Orico enclosre that is the same as yours to update my firmware a few times.
Just email me at tjw4700@yahoo.ca and I will send you the correct configure file.
Last edit: 1 year 6 months ago by Laroldski.
- diptadg
1 year 5 months ago
Hello, does anyone have config dump for the Orico PDDM2C3 or similar enclosures? I updated to the latest firmware 1.33.98 without creating a backup of the original config file.
Any help would be appreciated.
1 year 5 months agoHello, does anyone have config dump for the Orico PDDM2C3 or similar enclosures? I updated to the latest firmware 1.33.98 without creating a backup of the original config file.
I have 5 different configure files for the Orico enclosure's but the problem is they don't say enclosure they are for and I just got them by downloading a bunch of different RTL9210 firmware's from this site and then collecting them incase I needed them.
I would be more then happy to email them to you and you can try them,or you could also try contacting Orico I know at onetime they used to have the firmware for the enclosure on the same page that the enclosure is listed on and they have stopped doing that from what I can see.
I didn't see the firmware listed when I went to look for your enclosure under the support tab and then going to product support.
If you want to try the files I have email me at tjw4700@yahoo.ca I check that email once or twice a day from my and not my phone so I may not reply to your email right away.
- EL_HAM
Hello, I am a bit confused about creating a .cfg file. Can anyone help me to clear up the confusion?
I have a Jeyi Zebra-2230C (M.2 2230 NVMe Direct-attach) enclosure, Realtek RTL9210B.
Here's the dump:
Some questions:
- Is there any error in the config file I made? Or anything I should add, change, enable rather than removing it?
- Do I need to change or delete the bottom variable starting from "Boot Mode" to "Disconn"? I want to update it to the 1.33.98.090324 version from 1.32.49, but now this version page is missing 404. Is it defective/ pulled?
- Changed variables marked in BOLD. I don't add other variables I want from GitHub because I think it's not supported (because not being written by default), or I'm wrong?
What would happen if I did not remove the NVMe drive (other than risking the data, so I need to format it)? I put my custom thermal interface material on it, and it can be a bit frustrating to resemble it.
Next, I'll try to do something with the Orico M2PJM-C3. I have relatively new default firmware, but almost everything is N/A, including no DISK_IPS_THRES value, which causes it to use power even after hours of idle (based on my USB extender with wattage display). This makes it even more confusing why it was like that when I first saw it. It's quite different from the two M2PJM-C3 configs I found here. I hope I can just do it myself after I get it right on this first try with the Jeyi enclosure.
I apologize if I asked too much, thanks for your help in advance.
Here's the dump:
According to the GitHub page RTL9210 by bensuperpc, tab "Create your own configuration", I need to delete the first 3 lines, comment out DISK_IPS_THRES, change : to =, and delete all variable definitions with n/a value unless I want to change it.**************************************************************
Device : [Port2] : Realtek RTL9210 NVME #0
PRODUCT : "RTL9210"
SERIAL : "012345678913"
DISK_HOTPLUG : n/a
LED : 0x03
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
DISK_IPS_THRES : 0x0a
SUSPEND_LED_OFF : 0x00
HW_LED_CFG : 0x00000000
SUSPEND_DISK_OFF : 0x07
FW Ver : 1.32.49
FW Build Date : 2023.04.14
IC Pkg Type : PCIE
It seems that my SSD is unable to put on L1 ASPM (always high idle, close to read benchmark) mode, and needs 10 minutes of idle before putting on power saving, and Windows debug says USB not entering Selective Suspend (it's already enabled in Power Options including PCIe max power saving, I need to put turn of hard disk to 1 minute to make it on power saving quickly, not disconnected and drive still accessible unless I access the file it will be active again). EN_UPS said to be USB Power Saving but GitHub has (?) as a doubt. I also want the device to show in case of SSD failure so I can easily know it's the SSD issue, and show the device product name instead of Realtek.VID = 0x0bda
PID = 0x9210
MANUFACTURE = "Jeyi"
PRODUCT = "Zebra 2230C"
SERIAL = "012345678913"
SCSI_PRODUCT = "Jeyi Zebra 2230C"
SCSI_VENDOR = "Jeyi"
LED = 0x03
ASPMDIS = 0x01
;DISK_IPS_THRES = 0x01
EN_UPS = 0x01
CUSTOMIZED_LED = 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SUSPEND_LED_OFF = 0x00
DIS_SHOW_EMPTY_DISK = 0x01
UART_DBG_PIN = 0x05
HW_LED_CFG = 0x00000000
SUSPEND_DISK_OFF = 0x07
FW Ver = 1.33.98
FW Build Date = 2024.09.03
IC Pkg Type = PCIE
Disconn_ForceUSB2 = false
Some questions:
Last edit: 1 year 5 months ago by EL_HAM.
@admin I thought I would ask you this and if you don't know maybe someone else will know why this is.
I have noticed that the RTL9210 chip has a really stupid quirk and that is if you use the Dump file method of trying to create your own backup copy of your configure file if you can't find the factory configure file for your enclosure.
I have a Hiksemi enclosure and I find I have to use configure file RTL9210B_CG_LED0.CFG which is the only one that works fine with that enclosure,I have also tried HIKSEMI_MD202.cfg but the led doesn't work at all with that configure file.
Here is my main point to this thread however,after I flash the enclosure with new firmware and use RTL9210B_CG_LED0.CFG and then check the Dump file they never for whatever the reason.
The stupidest part of it all is that you would think the firmware tool would make a clone of whatever it see's in the enclosure as far as the setting's go when you use the Dump file method which makes no sense at all.
This is the information on the RTL9210B_CG_LED0.CFG file.
;Configure Start
;U2PHY = 02 f4 9b e0 e1
;U3PHY = 02 d4 09 00 d5 00 80
VID = 0xbda
PID = 0x9210
MANUFACTURE = "Realtek"
SCSI_VENDOR = "Realtek"
PRODUCT = "RTL9210B"
SCSI_PRODUCT = "RTL9210B"
SERIAL = "012345678923"
DISK_HOTPLUG = 0x0
PINMUX1 = 0x0
PINMUX2 = 0x0
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x70
ASPMDIS = 0x0
;DISK_IPS_THRES = 10
;EN_UPS = 0x0
;PD = 0x0
LED = 0x1
;HW_LED_CFG = 0x0
;CUSTOMIZED_LED is 15 bytes
;CUSTOMIZED_LED = 01 01
;SUSPEND_LED_OFF = 0x0
;FAN = 0x0
;DIS_SHOW_EMPTY_DISK = 0x1
;FORCE_SATA_NORMAL_DMA = 0x0
UART_DBG_PIN = 5
;FINGER_PRINT_EN = n
;DISCONN_FORCE_USB2 = n
FORMAT_DISK = n
;INC_SERIAL = y
;PARTITION: GPT, MBR
PARTITION = "MBR"
;FORMAT: NTFS, exFAT
FORMAT = "NTFS"
LABEL = "My USB"
This is what the Dump file say's after flashing the enclosure.
Device : [Port4] : Realtek RTL9210B #0
PRODUCT : "RTL9210B"
SERIAL : "012345678923"
SCSI_PRODUCT : "RTL9210B "
DISK_HOTPLUG : 0x00
PINMUX1 : 0x00000000
PINMUX2 : 0x00000000
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : n/a
FW Ver : 1.33.98
FW Build Date : 2024.09.03
IC Pkg Type : PCIE/SATA
[img][img]https://i.imgur.com/qBL3BL1.jpg[/img][/img][img][img]https://i.imgur.com/qBL3BL1.jpg[/img][/img]
;Configure Start
VID = 0xbda
PID = 0x9210
DISK_HOTPLUG = 0x0
PINMUX1 = 0x0
PINMUX2 = 0x0
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x70
ASPMDIS = 0x0
;EN_UPS = 0x0
;PD = 0x0
LED = 0x1
;HW_LED_CFG = 0x0
;FAN = 0x0
UART_DBG_PIN = 5
FORMAT_DISK = n
;INC_SERIAL = y
PARTITION = "MBR"
FORMAT = "NTFS"
LABEL = "My USB"
DISK_HOTPLUG : 0x00
FW Ver : 1.33.98
Last edit: 1 year 5 months ago by Laroldski.
