1 year 8 months ago
for me the problem seems to come from the disk cache if I'm not mistaken have you updated the disk firmware if it exists
  • AOnurY
  • AOnurY's Avatar
  • User
  • User
1 year 8 months ago
Disable antivirus and try again
  • yasins
  • yasins's Avatar
  • User
  • User
1 year 8 months ago
Onur hocam selamlar, RTL9210 chipli bir box almıştınız. Aliexpress üzerinden aldıysanız kapıda herhangi bir vergi ücret vs. verdiniz mi ? Bende almayı düşünüyorum ancak vergi çıkar mı diye merak ettim ?
  • AOnurY
  • AOnurY's Avatar
  • User
  • User
1 year 8 months ago
DM den yazdım dostum.
  • chaosdeus
  • chaosdeus's Avatar
1 year 8 months ago
Yes. I did a quick check by open BG3 from the ssd after I updated the firmware. Only few minutes after you posted the latest firmware 1.33.98.090324. My only antivirus is Windows Defender and while updating it was really quiet.
Do you mean that if problem exists after firmware updated, it could come from disk cache?
Thanks for reply.
