- yasins
- User
1 year 8 months ago
Hello, does anyone have the original dump file of the m2pv-c3 box? For some reason, while copying, it slows down every 3 seconds, waits for 1 second and continues. I bought it before flashing the firmware, but I noticed later that the file was deleted, now I can't go back to the original version because I can't find the dump file and which version it came with? Does anyone have this box and have the same problem? I'll have to send it to the warranty
Tested Firmware;
1.32
1.33
1.33.98
1.23
Tested Firmware;
1.32
1.33
1.33.98
1.23
1 year 8 months ago - 1 year 8 months agoHello, does anyone have the original dump file of the m2pv-c3 box? For some reason, while copying, it slows down every 3 seconds, waits for 1 second and continues. I bought it before flashing the firmware, but I noticed later that the file was deleted, now I can't go back to the original version because I can't find the dump file and which version it came with? Does anyone have this box and have the same problem? I'll have to send it to the warranty
Tested Firmware;
1.32
1.33
1.33.98
1.23
Just so you know I have that same Orico enclosure that you have and for the money the enclosure in this link is a much better deal as far as how well it's built and the quality,the aluminum is also fairly thick as well.
It use the JMS583 controller which I find to work just as well as the RTL9210 and you can also get replacement boards for it as well if you ever damage the USB-C connector.
[url] www.aliexpress.com/item/1005005977099067...n.211.591118024wacko [/url]
[url] www.aliexpress.com/item/1005005626954170...n.186.591118024wacko [/url]
Last edit: 1 year 8 months ago by Laroldski.
- blackbile
1 year 7 months ago
Hello guys,
is this the latest firmware for 9210B?
Realtek RTL9210(
NVMe/USB 3.1 Controller firmware Version 1.33.98.090324
Realtek RTL9210(
NVMe/USB 3.1 Controller firmware Version 1.33.98.090324 Please Log in or Create an account to join the conversation.
1 year 7 months ago
Yes 1.33.98 is the latest firmware for the RTL9210 right now.
- yasins
- User
1 year 7 months ago
Orico m2pv-c3 do you have the dump file? Also, the dump file that came out of the stock box? The warranty company did not accept the problem. Now it's just me and my box
Is ugreen cm559 good?
Is ugreen cm559 good? Please Log in or Create an account to join the conversation.
