- mircolino
Sorry, made a mistake. How do I delete this post?
- mircolino
il y a 1 an 3 moisYes, nvmupdatew64e.exe can still see the NIC:Can nvmupdatew64e "see" the NIC?
Can you post the content of:
nvmupdatew64e.exe -i -l yourlogname.log
C:\>nvmupdatew64e.exe -i -l
NVMUpdate version 1.39.56.9
Copyright(C) 2013 - 2023 Intel Corporation.
Config file will not be read.
Inventory
[00:100:00:00]: Intel(R) Ethernet Controller (3) I225-V
Flash inventory started.
Shadow RAM inventory started.
Flash inventory finished.
Vendor : 8086
Device : 15F3
Subvendor : 17AA
Subdevice : 22D8
Revision : 3
LAN MAC : <MAC_ADDRESS>
Alt MAC : 000000000000
SAN MAC : 000000000000
ETrackId : 800002FC
SerialNumber : <SERIAL_NUMBER>
NVM Version : 1.137(1.89)
PBA : G23456-000
VPD status : Not set
VPD size : 0
checksum : Valid
- Districtor
il y a 1 an 3 moisWell, what worked for me (my case was a little different):Yes, nvmupdatew64e.exe can still see the NIC:Can nvmupdatew64e "see" the NIC?
Inventory
Vendor : 8086
Device : 15F3
Subvendor : 17AA
Subdevice : 22D8
Revision : 3
ETrackId : 800002FC
PBA : G23456-000
VPD size : 0
checksum : Valid
Create nvmupdate.cfg or .txt, replace Vendor, Device etc. as needed.
Example:
CURRENT FAMILY: 1.0.0
CONFIG VERSION: 1.14.0
BEGIN DEVICE
DEVICENAME: NNT
VENDOR: 8086
DEVICE: 15F3
SUBVENDOR: 1043
SUBDEVICE: 87D2
NVM IMAGE: .\FXVL_15F3.bin
IMAGE DOWNGRADE: TRUE
END DEVICE
Then, nvmupdatew64e.exe -u -l -c nvmupdate.txt
If this doesn't work, you can try to add the -f (force) command. It might still output an error, however the file will be "written", after a reset it should work.
Also, see this link:
advantech-ncg.zendesk.com/hc/en-us/artic...-Adapter-710-Series-
Good luck!
Les utilisateur(s) suivant ont remercié: mircolino
- mircolino
il y a 1 an 3 moisIt worked! 😅Well, what worked for me (my case was a little different):
Example:
BEGIN DEVICE
DEVICENAME: NNT
VENDOR: 8086
DEVICE: 15F3
SUBVENDOR: 1043
SUBDEVICE: 87D2
END DEVICE
Good luck!
I think what I was missing was the "IMAGE DOWNGRADE: TRUE" entry in the config file. Thank you so much! 🙏🏻
For posterity, if you updated your Intel NUC I225 NIC with the ASUS 1.89 NVM image on this thread, and your NIC started misbehaving (mine kept disappearing after a reboot), assuming you created a backup of the previous EEPROM/NVM images with the command:
eeupdatew64e.exe /nic=1 /dump
The following will bring your NIC back to factory:
Create the following nvmupdate.cfg file:
BEGIN DEVICE
DEVICENAME: NNT
VENDOR: 8086
DEVICE: 15F3
SUBVENDOR: 17AA
SUBDEVICE: 22D8
NVM IMAGE: .\<MAC_ADDRESS>.bin
END DEVICE
Execute the following commands:
eeupdatew64e.exe /nic=1 /d .\<MAC_ADDRESS>.eep
nvmupdatew64e.exe -u -l -f -c nvmupdate.cfg
the NVM flash will fail but after you reset the NIC with the command below and power-cycle the NUC the I225 should be reset to factory
eeupdatew64e.exe /nic=1 /adapterreset
Use the following commands to verify everything is OK:
eeupdatew64e.exe /nic=1 /eepromver
eeupdatew64e.exe /nic=1 /adapterinfo
- Avirun
il y a 1 an 3 mois
I sent a message to yor e-mail, thx to your response.
