  • nightfly2000
  • Portrait de nightfly2000
il y a 3 mois 6 jours
#4143
Any new solutions?
I have also a Asus B550-F and bricked my device after updating it to 1.94.
I  wasn´t able to downgrade to 1.89 again, because I got an FLASHimage authentication failed.
Saidly I have no Backup...
#4146
could you send us a picture Thx
Les utilisateur(s) suivant ont remercié: nightfly2000
  • nightfly2000
#4147
I managed to flash the nic in ubuntu. Now it worked also in windows. But I think I have mixed firmware 1.89 and 1.94.
The eeupdate doesn´t work in Windows and give me still the error.
Now it´s possible to use nvmupdate again.
I write down my old Device ID etc.
VENDOR: 8086
DEVICE: 15F3
SUBVENDOR: 1043
SUBDEVICE: 87D2
Now I have this:
Config file will not be read. Inventory [00:007:00:00]: Intel(R) Ethernet Controller (3) I225-V         Alternate MAC address is not set.         Flash inventory started.         Shadow RAM inventory started.         Shadow RAM inventory finished.         Flash inventory finished. [00:007:00:00]: Intel(R) Ethernet Controller (3) I225-V         Vendor                 : 8086         Device                 : 15F3         Subvendor              : 17AA         Subdevice              : 22D8         Revision               : 3         LAN MAC                : xxxx         Alt MAC                : 000000000000         SAN MAC                : 000000000000         ETrackId               : 800002FC         SerialNumber           : 7C10C9FFFF3D9EA0         NVM Version            : 1.137(1.89)         PBA                    : N/A         VPD status             : Not set         VPD size               : 0         NVM update             : No config file entry           checksum             : Valid
#4150
If you are on Windows 11, go via Windows PE
  • Portrait de Laroldski
il y a 3 mois 2 jours
#4157
@nightfly2000I have the Intel i225 controller on my X870E mobo and it's a terrible device anyway,I installed the driver for my device the first time I used my new system then I had to do a reformat and install Windows again and the driver installed fine but then my PC would disconnect from the Internet all the time,after I did a bunch of research I found out that the i225 has a lot of problems with not staying connected to the Internet.
I know your not having problems with your i225 disconnecting from the Internet but I purchased this PCI-e card as it is a cheap solution with a Realtek RTL8125B and if you get that card the driver hosted here at station drivers for it as well.
If you only have spare long PCI-e slots and no short ones this card will still work just fine in a long or shirt slot as well,I have tried it both ways.
www.aliexpress.com/item/1005005967045605...in.68.19521802aiNHEG
