- mircolino
il y a 1 an 3 moisI run into the exact same problem: "Shared Flash image update FAILED! Pointers in Shadow RAM are corrupted"Nevermind, fixed it by using nvmupdatew64e with the -f (force) command.
Do you have more details on how you were able to fix it? Which nvmupdate.cfg file did you use? The exact nvmupdatew64e.exe command line?
Thank you! 🙏🏻
il y a 1 an 3 mois
Hi, what motherboard and network chipset do you have because normally the update works perfectly
- mircolino
il y a 1 an 3 mois
I have an Intel NUC NUC12WSKi7, the original NVM was v1.85.
Before upgrading to v1.89 I saved a dump of both the EEPROM and the NVM images.
After the update I noticed the NIC is now misbehaving and stops working when I restart Windows 11 ( community.intel.com/t5/Intel-NUCs/Intel-...ct-or-a/td-p/1548693 ).
So I decided to restore v1.85, but when I tried to flash the NVM I got the error "Shared Flash image update FAILED! FLASHimage authentication failed"
I tried a second time and eeupdatew64e.exe got stuck for 1 hour and I had to reboot the NUC.
Now if I try to flash the NVM I get the error "Shared Flash image update FAILED! Pointers in Shadow RAM are corrupted".
It looks like the I225-V is completely bricked now🤦🏻
You have an I225-V or LM Rev 1.x , 2.x , then try to update the bios, the drivers
- mircolino
My Intel NUC12 has a I225-V Rev 3 (PCI\VEN_8086&DEV_15F3&SUBSYS_22D817AA&REV_03) which now, after flashing the NVM v1.89 has a Lenovo branding (SUBSYS_22D817AA)🤦🏻
I flashed the NUC with the latest BIOS which however doesn't update the NIC NVM.
I'm using the latest Windows 11 driver (e2fn.inf 2.1.3.15), but I'm not sure how is this affecting the NVM flashing process.
