- EDU5K
il y a 1 an 2 mois
Hi i have B550-E I225-V REV2 how do i go back to the factory version? i didn't like 1.89
il y a 1 an 2 mois
If you have made a backup try to reuse the ROM backup but it does not work all the time
- cem1
il y a 1 an 2 mois
I have B550f gaming wifi 2 asus motherboard.
I already took a backup, but i'm getting the following error.
How can i proceed?
1: Shared Flash image update FAILED! FLASHimage authentication failed
Thanks
How can i proceed?
Thanks
- QuadDamage
il y a 1 an 1 mois
@cem1 , @EDU5K
Read my post:
www.station-drivers.com/index.php/en/for...n-1-89?start=95#2157
I have checked these both B550-F and B550-E motherboards. It seems that I am able to recover your original firmwares easly. If you don't have backups, I can create 1:1 copies of your original image files. There will be impossible to discover any modifications on the motherboards - the warranty will be back if you still have one
Till now, 5 people from this forum asked me for help and every time all ended with success.
So if you are interested - read the post and conctact me
Read my post:
- cem1
I have both eep and bin backups but i am getting following error during restore.
