  • janos666
  • Portrait de janos666
il y a 2 ans 10 mois - il y a 2 ans 10 mois
Yes. I tried both the USB 3.2 Gen2 (CPU SoC) and USB 2.0 (additional HUB connected to chipset provided USB 3.x) ports.
The board clearly goes into a "boot loop" (or boots and resets). I think this is because I have an incorrect config now.
This is the board I tried to flash. I guess I should have been more careful and realize that not all boards might work with all .bin and .cfg file combinations:
[url] photos.app.goo.gl/kin7ttCgepyoz17PA [/url]
I contacted the Aliexpress seller but they can't provide any kind of firmware (including the original these boards are shipped with).
  • cyberlan
  • Portrait de cyberlan
Ok, It was a problem with the .cfg file.
To make it work:
- Dump -> Show Device Info -> Save
- Delete first 3 lines and all the lines after the empty line towards the end
- Substitute all the ":" characters with "=" characters
- Save as .cfg and use it in UTHSB_MPtool_Lite
Hope this is useful to someone else!
this tips solved my problem, to update fw thanks a lot, but the freezing problem after idle time continues
  • janos666
Looks like my only option is to find oneone with an identical board and give me a config dump.
Or me buying yet another identical and do it for myself. -> What are my chances of recovering that way?
  • Jþ
  • Portrait de Jþ
Hi, I bricked my Orico SSD NVMe enclosure with the RTL9210B.
I read that you can reset the flash memory connecting the 1 & 8 pin, but I do not which its the chip.
Someone can help with the pictures please?
Thx!
[img
  • janos666
IT's usually the one with the hole and the one on the other side. Although, if you already over-written the config, I don't know how to recover from that.
Could you please sump your config onnce you get it into recovery mode?
