- Blast Beat
1 year 9 months ago
last attempt made with the electrician's tweezers and the smartphone as a microscope, still no result.
The rom is a Puya P25D40H
- JimmieDamn
@sdefrwggerg
Could you please reupload the configs files folder? I desperately need the AM8180 config file.
If someone else has it, please share it!
Here is the dump (it's a "Lemorele" enclosure)
Device : [Port3] : AMicro AM8180 NVME #0
VID : 0x1de1
PID : 0xe101
MANUFACTURE : "AMicro"
PRODUCT : "AM8180"
SERIAL : "012345681564"
SCSI_PRODUCT : "AM8180 NVME "
SCSI_VENDOR : "AMicro "
DISK_HOTPLUG : 0x00
PINMUX1 : 0x00000000
PINMUX2 : 0x00000070
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : n/a
RM_INTERNAL_RD : 0x01
FW Ver : 1.27.23
FW Build Date : 2021.09.06
IC Pkg Type : PCIE
Last edit: 1 year 9 months ago by JimmieDamn.
- Blast Beat
1 year 9 months ago
Finally went good
Used the front port of another pc.
Not sure it was bricked because when i insert the usb cable on the second pc, windows recognise it soon.
My main pc need a format
1 year 9 months ago
@JimmieDamn Here is the file your wanting download it from the link.
[url] www.sendspace.com/file/eetjfv [/url]
- JimmieDamn
@Laroldski
Ok thank you very much.
Now when I select that config file that you uploaded, the uthsb tool lite doesn't select the firmware bin and GD. I'm trying to flash the latest v1.33.44 driver, but it doesn't select the files when I try to flash to the Lemorele AM8180 enclosure. I've tried renaming the firmwares with "AM8180" but no luck. How should I modifiy the bin files so that I can select them?
