  • Blast Beat
  • Blast Beat's Avatar
1 year 10 months ago
Hello everyone,
i got an enclosure JEYI i9GTR-2280 bought on Aliexpress with a RTL9210 chip and a very old firmware v1.21.17.
The goal is to flash  v1.29.12.
Windows see the enclosure as RTL9210 but on the pcb i can read 9210B.
This is my dump file, can you please edit it?
************************************************************** Device : [Port7] : Realtek RTL9210 NVME #0 ************************************************************** U2PHY : 02 f4 9b e0 e1  U3PHY : 02 d4 09 00 d5 00 80  VID : 0x0bda PID : 0x9210 MANUFACTURE : "Realtek" PRODUCT : "RTL9210" SERIAL : "012345679060" SCSI_PRODUCT : "RTL9210 NVME    " SCSI_VENDOR : "Realtek " DISK_HOTPLUG : 0x00 LED : 0x01 PINMUX1 : 0x00070000 PINMUX2 : 0x00000000 U2_MAXPWR : 0xfa U3_MAXPWR : 0x70 ASPMDIS : 0x00 PCIE_REFCLK : n/a DISK_IPS_THRES : n/a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : n/a SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : n/a FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a FP_UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a EFUSE :         00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F        ------------------------------------------------- Boot Mode : Flash FW Ver : 1.21.17 FW Build Date : 2020.04.14 IC Pkg Type : PCIE UUID : n/a Disconn_ForceUSB2 : 0x00
Hi ,on the definition that Windows detects it does not matter whether it is a RTL9210 or 9210B because you can name it whatever you want as mine is an Asus TUF A1
The following user(s) said Thank You: Blast Beat
  • Blast Beat
OK so to go forward can i use the text below as config file named RTL9210B_CG_Lite.cfg ?
I am asking because MpTool v1.12 in the zip file leave almost everything locked
;Configure Start ;=================FW Configure================= ************************************************************** Device : [Port7] : Realtek RTL9210 NVME #0 ************************************************************** U2PHY : 02 f4 9b e0 e1  U3PHY : 02 d4 09 00 d5 00 80  VID : 0x0bda PID : 0x9210 MANUFACTURE : "Realtek" PRODUCT : "RTL9210" SERIAL : "012345679060" SCSI_PRODUCT : "RTL9210 NVME    " SCSI_VENDOR : "Realtek " DISK_HOTPLUG : 0x00 LED : 0x01 PINMUX1 : 0x00070000 PINMUX2 : 0x00000000 U2_MAXPWR : 0xfa U3_MAXPWR : 0x70 ASPMDIS : 0x00 PCIE_REFCLK : n/a DISK_IPS_THRES : n/a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : n/a SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : n/a FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a FP_UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a EFUSE :         00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F        ------------------------------------------------- Boot Mode : Flash FW Ver : 1.29.12 FW Build Date : 2022.11.01 IC Pkg Type : PCIE UUID : n/a Disconn_ForceUSB2 : 0x00 ;=================Tool Configure================= ;DISCONN_FORCE_USB2 = n FORMAT_DISK = n ;INC_SERIAL = y ;PARTITION: GPT, MBR PARTITION = "MBR" ;FORMAT: NTFS, exFAT FORMAT = "NTFS" ;LABEL max allowed - characters LABEL = "My USB"
  • Laroldski's Avatar
@Blast Beat download the file from this link it is the original file that you are looking,it is the configure file for the JEYI i9GTR [url] www.sendspace.com/file/uhxw85 [/url]
Sorry for the double post I did not mean to do that.
Last edit: 1 year 10 months ago by Laroldski.
  • Blast Beat
1 year 9 months ago
Thnks you  Laroldski
I download the latest file for the version "A" here
Realtek RTL9210(A-B) NVMe/USB 3.1 Controller firmware Version 1.30.21.070622
There was already in the configure folder a file named jeyi.cfg, i edit it just with my serial, than i used UTHSB MPtool Lite V1.14.8.0610 present in the main folder and full unlocked as you can see in the image attached.
From my point everything was right, i toke off the ssd, i switched off even the windows antivirus.
Few second after i started the update, i got an alert from the os (Win 11) of unknown device and few second later the flash procedure got error
I bricked my enclosure
