  • romeojr
  • romeojr's Avatar
2 years 9 months ago
I tried the 1.32.87.....same thing, no led, no touch button :(
  • TheGiolly
  • TheGiolly's Avatar
Hi everyone!!!
I have a JEYI model I9X, it´s have a screen that shows informations about the ssd, and a finger touch to change the screen.
The led ( the green one, on the left side) is not turning on, and the touch button is not working (on the right side) , anyone have the correct configuration for him?
can please send to me or show me how to fix?
Thanks a lot!
Did you update the Realtek firmware and then it stopped working?
Or it wasn't wasn't already working?
Last edit: 2 years 9 months ago by TheGiolly.
  • romeojr
  • romeojr's Avatar
It wasn´t work, I´m trying to fix upgrading the firmware, i tried somes but no changes......can someone send me the dump file from one that´s working?
  • galaxyinfire
  • galaxyinfire's Avatar
Hello, i have troubling with rtl9210b-cg and micron sata ssd 1Tb on windows 11, only woking with usb 2.0(as usb mass storage). In same time unknown chinese sata ssd 120gb working propertly over usap.
I understand little about the topic of controllers and usb and my question: is any way to disable usap(on controller.. config?) to using bot with usb 3.+ ?
  • flexman
  • flexman's Avatar
2 years 8 months ago - 2 years 8 months ago
UnionSine MD202 (RTL9210B) NVME USB BOX factory firmware 1.29.12, has been updated to 1.32.49
Checking connection on a laptop with a 7840HS, two USB C 3.2 Gen 2 ports. On the left port box works only in USB2 mode, when the cable is turned over to the other side - box is not detected at all, on the right port it works correctly in any position of the cable. Another USB>MSATA box on JMICRON with the same cable works in USB3 mode in any position.
Maybe something needs to be corrected in the box config?
config
Last edit: 2 years 8 months ago by flexman.
