2 years 8 months ago
Ask the manufacturer there's just no firmware for it and that's why you won't get any further.And this her is about RTL9210.
- symbios24
- User
2 years 7 months ago
there is nowhere to ask about it, i search in the manufacturer and nothing.anyway thanks
then all you have left to do is buy a new with RTL9210 chipset. Unfortunately, that's all you can do.
forums.raspberrypi.com/viewtopic.php?t=362991
- anonHZQT
Hello
I just bought the asus tuf gaming a1, and I heard all that use realtek 9210b chipset should update it firmware, I search online and the tools seem to be from here.
I don't want to broke my tuf a1 so here I ask, how to update fw without breaking it. I read that if there is problem with the update, with dump info then I would know what the original parameter are, but how to revert the update with that dump info I save before perform an update?
If any one here can provide me step about what to do and answer me how to prevent it from brick that would be a lot of help (I read here there a bridge 1 and 8 pin to reset? but I'm not confidence enough to do that)
here is my dump info
Device : [Port2] : TUF ESD-T1A #0
VID : 0x0b05
PID : 0x1a8a
MANUFACTURE : "ASUSTek"
PRODUCT : "TUF Gaming A1"
SERIAL : "NBD0AP055936"
SCSI_PRODUCT : "ESD-T1A "
SCSI_VENDOR : "TUF "
DISK_HOTPLUG : 0x00
PINMUX1 : 0x00000000
PINMUX2 : 0x00000000
DISK_IPS_THRES : n/a
CUSTOMIZED_LED : n/a
HW_LED_CFG : 0x80000081
FW Ver : 1.29.391
FW Build Date : 2022.07.28
IC Pkg Type : PCIE/SATA
the reason I want to update my tuf a1 is because the writing speed, reading speed is as what the spec was, but the writing speed is not.
VID : 0x0b05
PID : 0x1a8a
DISK_HOTPLUG : 0x00
FW Ver : 1.29.391
Hi, you can update it without any problem, you just need to retrieve the configuration file to use it for the update
www.station-drivers.com/index.php/en/les...t-asus-tuf-gaming-a1
