- wade7575
3 years 3 days ago
@blackbile have you updated the firmware for that enclosure and if so can you post how to do it.
Thanks a bunch.
Thanks a bunch.
- blackbile
3 years 3 days ago - 3 years 3 days ago
I have not got this unit, I just wanted to help you with the review photo...
Though as it is NOT Realtek chip I could not know how could you do it.
There is the another review:
"Asmedia ASM2364 which is fine in terms of pure performance, but will not allow you to do SMART or low level access to the disk for FW upgrades. I did manage to update the firmware for the ASM2364 chip using a generic Asmedia flash a utility from Startech, as Yottamaster will not provide anything."
Last edit: 3 years 3 days ago by blackbile.
3 years 3 days ago
I have both an ASM2362 & 2364 case but each chipset works with their respective firmwares
- Galixte
3 years 2 days ago
I have all three ASM2362, ASM2364 & ASM2464PD enclosures but each chipset works with their respective firmwares.
- wade7575
3 years 2 days ago
I understand the ASM chips working with their respective firmware but what I'm not sure about is do you also have to use a certain Configure file the way you do when flashing a RTL9210B controller.
