UGREEN Housing with an RGB light strip. When the housing transmits data, the color gradient of the RGB light is automatically generated.
So they RGB IC communicates with RTL via bus to change the light. So you need Special Firmware or / and API communication and i think it is different to sabrent.
The following user(s) said Thank You: programervn
1 year 3 months ago - 1 year 3 months agoYes, the Ugreen case is definitely more beautiful, I think.
on the other hand it heats up hence I added silicone paste above (normal) but below and under the realtek chipset to have contact with the aluminum case
- programervn
You can remove the mainboard by releasing the clips as shown in the picture I shared in the previous post. However, it’s very difficult to keep the case in its original condition, as it will get scratched when pried open. I managed to remove it successfully and added a thermal pad for the chipset. The sturdy design makes it quite difficult to take apart
1 year 1 month ago
I was wondering if anyone has the correct firmware for the Ugreen 20GBPs version of this enclosure that use's the RTL9220.
[url] www.aliexpress.com/item/1005004622441562...ain.5.31151802NrCIo2 [/url]
