3 years 7 months ago
Hi ,
yes it is better to resume the original configuration and modify the configuration file.
Personally, I always take the default Realtek configuration.
  • ikerrg
  • ikerrg's Avatar
Thanks for the quick reply. So can I just update the firmware with the default .cfg file? Here is the dumped info from my enclosure, please tell me which data should I keep/copy into the .cfg file.
Device : [Port1] : Inateck FE202x Series #0
U2PHY : 02 f4 9b e0 e1
U3PHY : 02 d4 09 00 d5 00 80
PRODUCT : "RTL9210B-CG"
SERIAL : "012345671111"
SCSI_PRODUCT : "FE202x Series"
SCSI_VENDOR : "Inateck"
DISK_HOTPLUG : 0x00
LED : 0x02
PINMUX1 : 0x00000000
PINMUX2 : 0x00000070
DISK_IPS_THRES : 0x0a
CUSTOMIZED_LED : n/a
DIS_SHOW_EMPTY_DISK : 0x01
FP_UART_BAUD_RATE : n/a
EFUSE :
   0   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  10   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  20   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  30   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  40   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  50   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  60   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  70   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  80   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  90   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  a0   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
  b0   ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Boot Mode : Flash NM
FW Ver : 1.28.19
FW Build Date : 2021.11.30
IC Ver : 0xa0010002
IC Pkg Type : PCIE_SATA
Disconn_ForceUSB2 : 0x00
Ok you just have to compare and update the default file but nothing prevents you from updating with the default file and seeing if it works well and saving the configuration of the old firmware here
  • ikerrg
  • ikerrg's Avatar
I just updated to 1.32 and it all went fine. I still want to do more tests but all good so far. Just a couple of questions:
- The serial number was increased by one after flashing (I checked in the new dump info). Do you know why is that? It seems that it is needed to subtract 1 from the actual serial number that you want to set in the firmware.
- The LED is still ON after a software eject. Is it possible to make it OFF when the enclosure is ejected?
Regards.
  • ikerrg
  • ikerrg's Avatar
The serial number increment can be avoided by removing the option in the menu (or editing the .cfg file). The LED correctly turns off after eject if SUSPEND_LED_OFF is activated before flashing. My .cfg file ended being as shown below:
;Configure Start
U2PHY = 02 f4 9b e0 e1
U3PHY = 02 d4 09 00 d5 00 80
VID = 0xbda
PID = 0x9210
MANUFACTURE = "Realtek"
SCSI_VENDOR = "Inateck"
PRODUCT = "RTL9210B-CG"
SCSI_PRODUCT = "FE202x Series"
SERIAL = "012345678931"
DISK_HOTPLUG = 0x0
LED = 0x2
PINMUX1 = 0x0
PINMUX2 = 0x70
U2_MAXPWR = 0xfa
U3_MAXPWR = 0x70
ASPMDIS = 0x0
;10 minutes of idle time will disable pcie power
DISK_IPS_THRES = 0xa
;EN_UPS = 0x0
;PD = 0x0
;CUSTOMIZED_LED is 15 bytes
;CUSTOMIZED_LED = 01 01
SUSPEND_LED_OFF = 0x1
FAN = 0x0
DIS_SHOW_EMPTY_DISK = 0x1
;FORCE_SATA_NORMAL_DMA = 0x0
UART_DBG_PIN = 5
;FINGER_PRINT_EN = n
;DISCONN_FORCE_USB2 = n
FORMAT_DISK = n
;INC_SERIAL = y
;PARTITION: GPT, MBR
PARTITION = "MBR"
;FORMAT: NTFS, exFAT
FORMAT = "NTFS"
LABEL = "My USB"
