- semaf
3 years 7 months ago
The links are not working to the firmware..
- wade7575
Give a bit of time I'm sure it's just a minor bug or something.
- wade7575
3 years 7 months ago - 3 years 7 months ago
@mushroom What installer did you use to flash the enclosure that's bricked,I had an enclosure fail when I tried using UTHSB_MPtool_Lite try using UTHSB_MPtool_Lite_Mini that worked to fix n enclosure of mine that failed when I tried flashing an enclosure and it failed.
Also try different configure files I had to try that as well,I have found that RTL9210_Lite_10.cfg seems to be a very common file used by a lot enclosure's.
I'm pretty sure that the latest firmware RTL9210B v1.32.16 found on this site has everything I mentioned.
Download firmware v1.30.21.070622 and take the contents of that configure folder and add them to v1.32.16 configure folder,try the configure file I suggest above first keep trying others to see if it will finally take one.
Last edit: 3 years 7 months ago by wade7575.
- ikerrg
I have a Inateck FE2025 enclosure with RTL9210B-CG chipset (
www.inateck.com/products/m-2-nvme-hard-d...ble-tool-free-fe2025
) , and I would like to update its firmware version to 1.32. Before doing that, I would like to share with you the dumped configuration for other people. What is the best way to do that? For the update, should I just copy those values to the .cfg file and flash the firmware?
Regards.
Regards.
Last edit: 3 years 7 months ago by ikerrg.
