- jelb0
2 weeks 2 days ago
Another Jeyi enclosure with a newer chip. RTL9201-VB-CG with 9.34.11.
Device : [Port2] : Realtek RTL9201 #0
PID : 0x9201
PRODUCT : "RTL9201"
SERIAL : "012345679085"
SCSI_PRODUCT : "RTL9201 "
DISK_HOTPLUG : 0x03
LED : n/a
PINMUX1 : n/a
PINMUX2 : n/a
U2_MAXPWR : n/a
U3_MAXPWR : n/a
ASPMDIS : n/a
DISK_IPS_THRES : 0x0a
CUSTOMIZED_LED : 35 01 02 00 00 00 00 00 00 00 00 00 00 00 00
UART_DBG_PIN : n/a
SUSPEND_DISK_OFF : 0x01
FW Ver : 9.34.11
FW Build Date : 2024.10.25
IC Pkg Type : SATA
2 weeks 2 days ago
Yeah 9.34.11 is on mydigit.cn but i dont have a chinese id to register for the website being in the uk and all
i was hoping someone would mirror it on mega or something
www.station-drivers.com/index.php/en/for...1-32-7?start=20#5603
- jelb0
2 weeks 2 days ago
At least it seems my version is the latest.
I know it's not a troubleshooting forum, but my SATA NVME keeps getting disconnected in this enclosure. The whole drive just disappears. I was successfully able to do a full 240GB h2testw run, getting it to 65 degrees, without disconnecting. But whenever I leave it idle for a minute, it's gone...
2 weeks 2 days ago
only a ch341a
only a ch341a
- jelb0
2 weeks 2 days agoDo you suggest me trying to flash 1.32.7 from your opening post ? After making my own custom .cfg using these instructions ? I don't know how an SPI backup works, but it sounds like it's a chip backup made by connecting it in some direct hardware way.[...] 1.32.7 is fine (we have a realtek flashable updater from windows
then flash 1.32.7 and see if its fixed [...]
