11 months 2 weeks ago - 9 months 4 weeks ago
Official release by Intel® of v24.0.1.1 of the Intel® Wireless Bluetooth Driver on December 9, 2025
Important Notice
Direct Drivers Downloads:
Windows 11 Family*, Windows 10, 64-bit*: downloadmirror.intel.com/870635/BT-24.0.1-64UWD-Win10-Win11.zip
Release Notes: downloadmirror.intel.com/870635/ReleaseNotes_BT_24.0.1.1_IT.pdf
Windows 11 Family*, Windows 10, 64-bit*: downloadmirror.intel.com/870633/BT-24.0.1-64UWD-Win10-Win11.exe
Release Notes: downloadmirror.intel.com/870633/ReleaseNotes_BT_24.0.1.1.pdf
Extracted drivers uploaded to Mega: mega.nz/file/BBlHRSZZ#jjesuPTSsIbfgE6uIp...V8bpBbtQ-wJSe7vdOnEY
Important Notice
- This software package includes drivers for new Intel® Wi-Fi 7 products* - Intel® Wi-Fi 7 BE211 and Intel® Wi-Fi 7 BE213.
- From the release 23.170.0 package onwards, Bluetooth drivers have been validated to support Microsoft Windows* 11 25H2.
- For PCs with Intel® Wireless-AC 9560, Intel® Wireless-AC 9462, Intel® Wireless-AC 9461: Before upgrading from 23.10.x.x - 23.50.x.x versions to this 24.0.1 driver, the user needs to disconnect all the Bluetooth® devices and unpair all the previously paired devices in the PC. Once the upgrade is complete, the user can repair the devices and connect them. Fixes for PCs with Bluetooth® drivers prior to 23.10.0 can be upgraded to 24.0.1.This software package includes drivers for the Intel® Wi-Fi 7 products - Intel® Wi-Fi 7 BE202, Intel® Wi-Fi 7 BE201 and Intel® Wi-Fi 7 BE200.
Warning: Spoiler!
- Driver version 24.0.1.1 : For BE213, BE211, BE202, BE201, BE200, AX411, AX211, AX210, AX203, AX201, AX200, AX101, 9560, 9462, 9461, 9260
- The drivers also work on Intel® Killer™ BE1750(x/w), BE1750(i/s), AX1690, AX1675, AX1650, 1550
The following user(s) said Thank You: wasisdn, duttyend
- FirstEver
11 months 2 weeks ago - 11 months 2 weeks agoThanks for the info!
For clarification, driver 24.0.1.1 is dated 23/09/2025 (not 9/12/2025)
The latest driver 24.10.0.4 (dated 10/11/2025) can be downloaded directly from the Windows Update server , or installed using my tool.
GitHub: [url] github.com/FirstEverTech/Universal-Intel-WiFi-BT-Updater [/url]
Direct: WiFi-BT-Updater-24.0-2025.11-Driver64-Win10-Win11.exe
Last edit: 11 months 2 weeks ago by FirstEver.
As I wrote, official release was December 9, 2025, that doesn't necessarily refers to the date it was compiled.
WHQL certification was October 6, inf file September 23.
Your downloader, though it's useful, is missing the ibtpci drivers, because they are not available from Microsoft.
Last edit: 11 months 2 weeks ago by Tom.
The following user(s) said Thank You: admin, THEBOSS619, duttyend
- FirstEver
Hi Tom - thanks for the feedback! I need to clarify a key technical point to avoid confusion.
You are correct that ibtpci drivers are not available from Microsoft. However, that's because ibtpci is exclusively a Linux kernel module. It is the component that handles Bluetooth for Intel combo cards in the Linux operating system.
My updater is designed for Windows. In the Windows ecosystem, Intel provides a single, unified driver package (delivered via .exe or Windows Update .cab files) that contains both the Wi-Fi and Bluetooth drivers bundled together. There is no separate ibtpci component; the Bluetooth functionality is integrated directly into the Windows driver (e.g., IntelBluetooth.inf and associated .sys files).
Therefore, the absence of ibtpci in my tool is not a missing feature—it's because ibtpci does not exist and is not relevant for Windows drivers. My tool installs the official, latest Intel drivers intended for Windows, exactly as they are distributed by Intel and Microsoft.
The following user(s) said Thank You: Fernando, THEBOSS619, duttyend, virgolicidaniel
11 months 2 weeks agoI wish I could agree with you, but if you download the extracted package which I uploaded to Mega, you will see that the folder iptpci contains a "ibtpci.inf" file, WHQL certification and a Windows binary called "ibtpci.sys".Hi Tom - thanks for the feedback! I need to clarify a key technical point to avoid confusion.
That the folder name is named "Win10_UWDRelease" is another clue that this driver is for Windows.
Still I agree with you that Microsoft is not publishing the "ibtpci.sys", therefore there is nothing to download.
