Updated the first post with an updated Realtek RTL9201R Station-Drivers.7z
I desoldered the SPI chip a couple of days ago on the Cofre Disco Duro FW 9.32.74 and dumped its contents hopeing to be able to separate the
Golden Firmware from the main Firmware and such there may also be an led.bin in there for the disco lights
couldnt seem to work out the firmware structure
if any hex editing gods are here it would be nice to get a backup of the firmware from the dump that can be flashed via MPtool_lite rather than having to flash with a programmer
files are in Realtek RTL9201R\Other\Cofre Disco Duro 9.32.74 SPI Dump
Last edit: 1 year 4 months ago by Shonk.
  • Pablo_24
  • Pablo_24's Avatar
1 year 4 months ago
1 year 4 months ago
the link on page one was updated
did i miss a link in a later post?
1 year 4 months ago
A Cofre Disco Duro that came today has the new firmware on it
will take a spi dump of it at some point
************************************************************** Device : [Port10] : Realtek RTL9201R #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9201 MANUFACTURE : "Realtek" PRODUCT : "RTL9201R" SERIAL : "012345678970" SCSI_PRODUCT : "RTL9201R        " SCSI_VENDOR : "Realtek " USB_SELF_PWR : 0x01 DISK_HOTPLUG : n/a LED : 0x01 PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : 0x0a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00 SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x64 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : n/a SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a Boot Mode : Flash FW Ver : 1.33.88 FW Build Date : 2024.07.18 IC Pkg Type : SATA UUID : n/a Disconn_ForceUSB2 : false
1 year 4 months ago
Added SPI Dump of Cofre Disco Duro 1.33.88 18th July 2024
Its in Realtek RTL9201R\Other\Cofre Disco Duro 1.33.88 SPI Dump
mega.nz/file/Aroh2KTB#Lz6PzPtUGrD0bBjRFY...a3D_kxUkv2EvRU8Yfb_c
