  • jelb0
  • jelb0's Avatar
3 months 3 weeks ago
Another Jeyi enclosure with a newer chip. RTL9201-VB-CG with 9.34.11.
************************************************************** Device : [Port2] : Realtek RTL9201 #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9201 MANUFACTURE : "Realtek" PRODUCT : "RTL9201" SERIAL : "012345679085" SCSI_PRODUCT : "RTL9201         " SCSI_VENDOR : "Realtek " USB_SELF_PWR : n/a DISK_HOTPLUG : 0x03 LED : n/a PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : 0x0a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : 35 01 02 00 00 00 00 00 00 00 00 00 00 00 00  SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : n/a FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : 0x01 SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a Boot Mode : Flash FW Ver : 9.34.11 FW Build Date : 2024.10.25 IC Pkg Type : SATA UUID : n/a Disconn_ForceUSB2 : false
Yeah 9.34.11 is on mydigit.cn but i dont have a chinese id to register for the website being in the uk and all
i was hoping someone would mirror it on mega or something
www.station-drivers.com/index.php/en/for...1-32-7?start=20#5603
  • jelb0
  • jelb0's Avatar
At least it seems my version is the latest.
I know it's not a troubleshooting forum, but my SATA NVME keeps getting disconnected in this enclosure. The whole drive just disappears. I was successfully able to do a full 240GB h2testw run, getting it to 65 degrees, without disconnecting. But whenever I leave it idle for a minute, it's gone...
only a ch341a
  • jelb0
  • jelb0's Avatar
[...] 1.32.7 is fine (we have a realtek flashable updater from windows
then flash 1.32.7 and see if its fixed [...]
Do you suggest me trying to flash 1.32.7 from your opening post ? After making my own custom .cfg using these instructions ? I don't know how an SPI backup works, but it sounds like it's a chip backup made by connecting it in some direct hardware way.
