SPI Dump added with Drive ID Passthrough
for Cofre Disco Duro on the latest 1.33.88 Firmware with working Disco..
This has to be programmed with a programmer ofc (CH341a etc..)
I just did my 5 Cofre Disco Duro's all went well
I have included 5 different SPI dumps with different SN's
Not much use to most people but may help someone
1.33.88 Passthrough SN 012345678970.bin Drive ID Passthrough in device manager
1.33.88 Passthrough + ID SN 012345678970.bin Drive ID Passthrough in device manager + USB Device ID Cofre Disco Duro
mega.nz/file/prpSgSAa#FyZ24FfE7p-tkArkGp...eCW2lXQLasseUGTC3onw
************************************************************** Device : [Port4] : ADATA SU 800 #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9201 MANUFACTURE : "Cofre" PRODUCT : "Cofre Disco Duro" SERIAL : "012345678975" SCSI_PRODUCT : "n/a" SCSI_VENDOR : "n/a" USB_SELF_PWR : n/a DISK_HOTPLUG : n/a LED : 0x01 PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : 0x0a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : 41 00 00 00 00 00 00 00 00 00 00 00 00 00 00  SUSPEND_LED_OFF : n/a FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x64 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : n/a SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a Boot Mode : Flash FW Ver : 1.33.88 FW Build Date : 2024.07.18 IC Pkg Type : SATA UUID : n/a Disconn_ForceUSB2 : false
Last edit: 1 year 5 months ago by Shonk.
The following user(s) said Thank You: Stasiz, abhishekt295
  • abhishekt295
  • abhishekt295's Avatar
11 months 3 weeks ago
hello guys, this Chinese website seems to offer latest firmware V4.32 for RTL9201R. i dont have acces to this site.
www.mydigit.cn/thread-521797-1-1.html
Realtek Numbering is always 1.xx.x
4.32 is an oem = bigger number is better
it will be 1.32.xx it doesnt say in the thread what the exact build is so it may be newer than 1.32.7
but isnt newer thanthe spi dump of the cofree disco duro that i have 1.33.88
9.34.11 + 9.33.88 is also here
1.34.11 + 1.33.88
You need weechat to register so i cant get it
if someone can put it on mega or something that would be great
Last edit: 11 months 3 weeks ago by Shonk.
The following user(s) said Thank You: abhishekt295
  • MichiMiMi
  • MichiMiMi's Avatar
8 months 5 days ago
Short question - is it possible to see the actual gdfw installed on the case?
8 months 5 days ago
You can sometimes get it to come up in a failsafe mode on the golden firmware but its super rare
im not sure of any other way
