  • simba
  • simba's Avatar
3 months 4 days ago
My hdd enclosure(RTL9201R) is on firmware 1.32.7 and is working correctly only on windows (usb 3 10Gbps speed) but would not show up on either mac (m2 pro), ios , android or linux, not even the usb is recognised. It uses external power adapter to power 3.5 inch drives. The drive works perfectly on mac os and other unix/linux when i use a usb 2 dongle albeit at usb 2 speeds. I have tried changing config settings but no luck. Does this chip not work with unix/linux or is this another problem on my enclosure
2 months 2 weeks ago
I had two UTHAI/ShuoLe U25N-L Enclosures arrive today they came with 1.34.29 Firmware
I have taken an SPI dump and edited it for Drive ID passthrough and such
It has 5 RGB LED's and does a nice rainbow effect
Here's its stock info
************************************************************** Device : [Port1] :          RTL9201R #0 ************************************************************** U2PHY : n/a U3PHY : n/a VID : 0x0bda PID : 0x9201 MANUFACTURE : " " PRODUCT : "RTL9201R" SERIAL : "012345678985" SCSI_PRODUCT : "RTL9201R        " SCSI_VENDOR : "        " USB_SELF_PWR : n/a DISK_HOTPLUG : n/a LED : 0x03 PINMUX1 : n/a PINMUX2 : n/a U2_MAXPWR : n/a U3_MAXPWR : n/a ASPMDIS : n/a PCIE_REFCLK : n/a DISK_IPS_THRES : n/a SWR_1_2V : n/a EN_UPS : n/a PD : n/a CUSTOMIZED_LED : 41 02 00 00 00 00 00 00 00 00 00 00 00 00 00  SUSPEND_LED_OFF : 0x07 FORCE_USB_SPEED : n/a FORCE_PCIE_SPEED : n/a EN_U1U2 : n/a FORCE_USB_QUIRK : n/a FORCE_PCIE_QUIRK : n/a FAN : n/a DIS_SHOW_EMPTY_DISK : n/a FORCE_SATA_NORMAL_DMA : n/a UART_DBG_PIN : 0x64 FINGER_PRINT_EN : n/a RM_INTERNAL_RD : n/a HS_AUTO_SWITCH : n/a UART_BAUD_RATE : n/a CUSTOMIZED_DISK_IDENTIFY : n/a HW_LED_CFG : n/a CDROM_CFG : n/a SUPPORT_HID : n/a LATE_INIT_DISK : n/a SCSI_WP_PIN : n/a SD_MMC_TYPE : n/a FORCE_PORT_TYPE : n/a BCDDEVICE : n/a SUSPEND_DISK_OFF : n/a SCSI_WB_PIN : n/a CUSTOMIZED_FEATURE : n/a PERIPH_API : n/a RAID_CFG : n/a RW_MODE : n/a FORCE_SATA_QUIRK : n/a Boot Mode : Flash FW Ver : 1.34.29 FW Build Date : 2025.01.13 IC Pkg Type : SATA UUID : n/a Disconn_ForceUSB2 : false
  • jelb0
  • jelb0's Avatar
only a ch341a
Jeyi still hasn't come back to me about the issue. I suspect SUSPEND_DISK_OFF at 0x1 is the culprit. I won't do anything though, because I don't have the 9.34.11 firmware. If only I could download it from  www.mydigit.cn/thread-564463-1-1.html .
  • jelb0
  • jelb0's Avatar
2 months 1 week ago
They've sent me the firmware! It's still 9.34.11 but their .cfg fixes the disconnect after 1 minute issue.
VID = 0xbda PID = 0x9201 MANUFACTURE = "Realtek" SCSI_VENDOR = "Realtek" PRODUCT = "RTL9201" SCSI_PRODUCT = "RTL9201" SERIAL = "012345678924" DISK_IPS_THRES = 0 CUSTOMIZED_LED = 35 01 02  ;DISK_HOTPLUG = 0x3 SUSPEND_DISK_OFF = 0x1
wetransfer.com/downloads/5f7da54f1b393e5...0260701060827/e1c0d0
Something to pay attention to: Serial Number Settings > Increment Serial is enabled by default. I like to disable it.
The following user(s) said Thank You: Shonk, Stasiz
  • Stasiz
  • Stasiz's Avatar
  • poster 5
  • poster 5
2 months 1 week ago
Excellent firmware. PERIPH_API for LCD is now supported. I successfully flashed the ShuoLe enclosure with BW LCD.
